Help! How do I.......
I just got my chrome trunk bar and LED tail lights. How do I remove the factory trunk bar and the inner tail lights? Your input will be greatly appreciated.
For the trunk bar I pulled my liner half way down there are 4 10mm nuts and two white plastic pegs, 2 of the bolts are on the outer ends of the trunk lid with one plastic peg next to it while the other 2 bolts are in the center of the trunk lid that hold the trunk lock attached to the lid, remove these nuts and carefully push the bolts and the pegs outward, installation is reverse. For tail lights on the body of the car each light has 2 10mm nuts inside the trunk and on the outside there are two plastic caps pop those with a screwdriver and you will see 2 10mm bolts . while you are doing you trunk bar you can do your trunk lid lights 2 10mm nuts on each light hope that helps.
MIGS
SC- 1st Gen (1992-2000)
20
03-31-11 10:13 PM
