Retrofit Showoff!
Old 03-07-14, 08:55 PM
  #136
MikeFoxx
MikeFoxx's Avatar
Originally Posted by monkey92
just out of curiosity just how much do retrofitted headlights run for?!
Its cheaper to do your own $300-$500ish depending on A Lot of factors lol. But if you mean retrofitted as in buying someones complete set... Well supply and demand will drive that right up to the highest bidder. $500 plus stocks up to and past $1k
Just depends on what you are willing to pay really.
Old 03-07-14, 09:07 PM
  #137
monkey92
monkey92's Avatar
ahh i see, reason i asked is because im running infiniti M45s retros right now and i just wanted to see how much i could get out of them if i decided to part ways.
Old 03-07-14, 09:10 PM
  #138
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I would say between $600 to $800 . I've seen a lot go for the $600 area plus stock headlights to replace the retros
Old 03-09-14, 09:43 AM
  #139
Lveyolfe
Lveyolfe's Avatar
how does retrofitting with q45 headlight work? do i still need 6ks? orrrr...?
Old 03-09-14, 11:49 PM
  #140
Lutkis
Lutkis's Avatar
Didn't realize people ask that much of them.
That's about double for what I paid for my retrofit overall.
Yes you'll need HID kit if you don't already have 'em on your stocks.
Even if you have stock HID's you'll still need new bulbs 'cause the stock ones are D2R and those Q45's need D2S'.
I'd recommend 5000K but each to its own.
Old 03-10-14, 12:18 AM
  #141
Aristo722
Aristo722's Avatar
Im planning on just buying a pair of clean retrofits. Doing them myself seem a bit challenging... but then again. When I bought my GS the previous owner already bought brand spankin new headlights. Not a spec of dirt or scratches or any yellow muck. I dont want to risk running a brand new set trying to do a retrofit myself. But, depends on how hard it is to do. How hard would it be to do a retrofit? What are the best projectors to retrofit into our housings anyway?
Old 03-10-14, 01:24 AM
  #142
tmf2004
tmf2004's Avatar
this might help your DIY
http://www.luxurymods.com/2gsdiyhidretrofit.aspx
Old 03-10-14, 01:45 AM
  #143
Lutkis
Lutkis's Avatar
If only it would have been that easy..
There's one very important part missing and that is how you attach the projectors onto the original bezels and how you get them aligned the exact same way on both sides.
That's one reason I did mine without the original bezels and it was a PIA to get them to fit and work properly.
Edit: You can check my topic of my retrofit to see what I had to go through. It is very crucial to pick the right projectors and shrouds right from the start because those are the things that define if the job is easy or not.
https://www.clublexus.com/forums/gs-...t-project.html
Old 04-16-14, 01:54 PM
  #144
sc-fsport
sc-fsport's Avatar
Here is my contribution fresh off the press! M45/35 with tinted housing oem, dneso ballast, 4300k, d2s bulbs, and I'm in love with the new appeal.
Attached Thumbnails Retrofit Showoff!-dsc05499.jpg   Retrofit Showoff!-dsc05501.jpg
Old 04-16-14, 01:56 PM
  #145
tmf2004
tmf2004's Avatar
looks good. I think it flows well instead of all the chrome especially on that color
Old 04-16-14, 02:56 PM
  #146
sc-fsport
sc-fsport's Avatar
Thanks it definitely took a lot of elbow grease lol but the results are exactly as i imagined to be, so I'm very pleased! What part of FL are you in?
Old 04-16-14, 03:01 PM
  #147
LudeNsoL
LudeNsoL's Avatar
Mine
Old 04-16-14, 03:23 PM
  #148
LudeNsoL
LudeNsoL's Avatar
A good friend of mine did these for me.
New Eagle Eye Headlights
Low beam
Morimoto mini projectors
5k hids
Porsche shrouds
Black painted bowl
High Beam
Morimoto mini projectors low beam delete
Mini gattling gun shroud
194 led
Amber signal delete
Blue Demon eye led
Old 04-16-14, 05:13 PM
  #149
tmf2004
tmf2004's Avatar
looks great.....
Old 04-16-14, 05:50 PM
  #150
marus
marus's Avatar
Talking
Not trying to show off or anything
Quick Reply: Retrofit Showoff!
