Retrofit Showoff!
Old 05-12-16, 04:01 PM
  #256
77i9
77i9's Avatar
sup Brian! I'm also on the look out for LS430 projectors, but sadly they are very hard to find even here in Japan. It's easier to find the LS460 ones than the LS430. But I'll let u know when I get a set that I want to sell.
Old 05-12-16, 07:48 PM
  #257
99 GS3
99 GS3's Avatar
I am building a new pair of headlights and will be selling my LS430 retro soon incase anyone is interested in them.
Old 05-12-16, 11:27 PM
  #258
SpectraBlu
SpectraBlu's Avatar
Damn, your car looks sick! I'm sure those retro's will sell quick. By the way thanks for your diy on your retrofit, I used Mrjokester and the one u did to do mine
Old 05-13-16, 07:55 AM
  #259
SoCal Cyco
SoCal Cyco's Avatar
what is a better retro than the ls430?
Old 05-13-16, 08:16 AM
  #260
PandaGS300
PandaGS300's Avatar
Hey so I just wanted some clarification about the Q45 Retro.
I have a NON-Hid gs300 headlight, I know to get the bracket from Luxrymod.com (http://www.luxurymods.com/retrofitbrackets.aspx) and of course the q45 housing.
For the factory high beam location, I want to place a morimoto mini Bi-xenon projector. What shroud do you guys recommend for this location?
Old 05-13-16, 10:20 AM
  #261
99 GS3
99 GS3's Avatar
Thanks!
430's are the widest output, and it's because of the hole under the projector that directs light spillage out to to the sides of the car, and is why 430 projectors are left and right specific. You must change the ****ty stock fresnal lens out for a crystal clear lens to get a sharp cutoff line and better output.
S2000 projectors have a very crisp cutoff with the most color flicker, and all around are a very nice projector.
TSX has great output and has one of the sharpest cut off lines for a stock projector.
Those three are the classics, all three are low beam only. Then there are alot of other options of modified, hybrid, bi-xenon, and replica projectors out there that are good in their own respects. There is no clear winner as to what is the best projector.
I had their Mini-D2s in the high beam of my 430 retro using the Gatling Gun shrouds. But after a couple months I took them out and put stock high beam bowls back in because I did not like how crowded the projector looked in small highbeam location, nor how busy it made the headlights look overall. I have since used the Mini-H1 version in a set I did for someone, and it was a bit better looking, but the Mini-H1 output isn't nearly as good looking as the mini-D2S.
The LS430 with clear lenses, Osram CBI bulbs, and 55w ballasts is so good I pretty much never use the highbeam for driving anyway, except to help read a street sign or something up high.
Old 05-13-16, 11:02 AM
  #262
MikeFoxx
MikeFoxx's Avatar
99 GS3 pretty much nailed it on the projector breakdown. The top level classics all have their strengths in different areas and once you start experimenting with the projector lens and then go into adding spacers you will get a range of results.
What I like about the ones smaller than the LS430 is that you can also get creative with the shroud. The M45 has one of my favorite shrouds which could be back lit with a separate led strip as a daytime driving feature. The Panamera shrouds are pretty nice too. Tons of custom shrouds out there that can be paired with the S2000 or TSX with a clear lens and possible a spacer or two. But I love the LS430 pattern when you are in the middle lane on the highway and you clear the darkness across all lanes, down the shoulder, and across the median.
Old 05-13-16, 12:09 PM
  #263
PandaGS300
PandaGS300's Avatar
Originally Posted by 99 gs3
thanks!
Tsx has great output and has one of the sharpest cut off lines for a stock projector.
I had their mini-d2s in the high beam of my 430 retro using the gatling gun shrouds. But after a couple months i took them out and put stock high beam bowls back in because i did not like how crowded the projector looked in small highbeam location, nor how busy it made the headlights look overall. I have since used the mini-h1 version in a set i did for someone, and it was a bit better looking, but the mini-h1 output isn't nearly as good looking as the mini-d2s.
The ls430 with clear lenses, osram cbi bulbs, and 55w ballasts is so good i pretty much never use the highbeam for driving anyway, except to help read a street sign or something up high.
Originally Posted by mikefoxx
99 gs3 pretty much nailed it on the projector breakdown. The top level classics all have their strengths in different areas and once you start experimenting with the projector lens and then go into adding spacers you will get a range of results.
What i like about the ones smaller than the ls430 is that you can also get creative with the shroud. The m45 has one of my favorite shrouds which could be back lit with a separate led strip as a daytime driving feature. The panamera shrouds are pretty nice too. Tons of custom shrouds out there that can be paired with the s2000 or tsx with a clear lens and possible a spacer or two. But i love the ls430 pattern when you are in the middle lane on the highway and you clear the darkness across all lanes, down the shoulder, and across the median.
thanks for the input guys!!!!!!!!
Old 07-14-16, 08:34 AM
  #264
FASTEDDY
FASTEDDY's Avatar
some of you guys have great set ups, i wish i had more time to build my own.
Old 09-27-16, 12:28 PM
  #265
tiguy99
tiguy99's Avatar
Thanks!
FACTS!
Its like having all the latest phones...no one is better than another...just personal preference and tons of cash spent collecting them all until you finally see for yourself
Old 02-12-18, 09:17 PM
  #266
Mackd1418
Mackd1418's Avatar
ES330 Projector same as RX330 Non-AFS Projectors
To mount them I made some brackets from sheet aluminum from Lowe’s and cut to fit the housing and back of projector.
Attached Thumbnails Retrofit Showoff!-5dd43c5e-454a-4629-9e86-e337e773f8ef.jpeg   Retrofit Showoff!-0cf4022c-7b50-45a4-acc9-90bb04b01924.jpeg   Retrofit Showoff!-8e71be7f-b789-4e46-b609-428bdab9d1dc.jpeg   Retrofit Showoff!-f8f88e6b-be78-4802-a04a-b9a4a49c34a2.jpeg   Retrofit Showoff!-bc32cce6-af8a-4550-82f0-8d60d3c3fc82.jpeg
Old 08-20-18, 10:30 AM
  #267
dreamcar88
dreamcar88's Avatar
im going to bump this thread. Im in the market for new headlights . I have poop green tint headlights non hid with 6k lights. Im not looking to spend 1000 but I want to find something thats clear lensed with better output for my hids. What do you guys suggest and or know of anyone who can do the ls430 mod with clear lesnes for me? If anyone has anything for sale or know anything please dm me. Ill even take factory clear lights and just wont run the self leveling. Its the last big piece i need done
Old 08-20-18, 12:21 PM
  #268
captainva
captainva's Avatar
You're probably going to be around the $1000 range if you have someone do the LS430 retro for you. I'm doing a retro now and with a second set of headlights and the projectors and brackets I'm in about $150 already. Take a look on ebay. There are a few retros that are already done you could buy.
https://www.ebay.com/itm/Lexus-GS-GS...n/253583727455
https://www.ebay.com/itm/Lexus-GS300...item3b152b630f
Any of the new projectors headlights from China will be trash so don't buy those.
dreamcar88 (08-21-18)
Old 08-20-18, 01:07 PM
  #269
silverbul
silverbul's Avatar
I did my own. LS430 projectors with luxury mods a little cutting and trimming along with clear lens and you got yourself a dangerous set of headlights. Oh don't the CBI 5500k bulbs
tiguy99 (08-30-18)
Old 08-21-18, 07:18 AM
  #270
dreamcar88
dreamcar88's Avatar
thanks, ya i seen those two on ebay but they both need new housings so im undecided on that
hmm looks good how far away in md are you? Im not far from md not sure if youd want to do this again lol
Quick Reply: Retrofit Showoff!
