Help Me Out On My Retrofit!!
Can I Do It Myself? Who Builds It Already Done?(q45)
Also How Can I Run All 4 Healights Across The Front At The Same Time? Aiming At A Low Beam Level, But With An Hid Conversion?
I Have 6000k D2r Bulb Replacements In My Headlights Now, What A Difference From Stock!! Althought I Want To Match My Inner Lights To Run With Them At The Same Time And Not Blind People......thanks For Your Help
Right Now I Just Have 6000k Hi-beams When I Click Them On, And I Want All 4 On And My Fogs.....thanks Guys
Tyler
Tyler
when you retrofit are you messing up the auto adjustments on the HID headlights? I have HID's already the stock ones. But i really like the M45 bullet type headlights. Is there a way to make the auto levelling work?
Has Anyone Put An Hid Kit In The High Beam? I Have Had Triubl Getting It To Power Up And Had To Run A Relay...i Think It Is Because The Daytime Running Lights Somehow Lower The Wattage Going To The 9005 Bulbs In The Hi-beam Location Creating A Wak Dim Light!! I Want Hid All The Way Across. I Was Thinking Of Fitting A Metal Hood Over The 9005 Bulb Itself(like An H4) To Keep It From Aiming So High And Blinding Oncomers.
What Do You Guys Think?
Tyler
Tyler
GRAND_LS 4
08-30-07 09:17 AM
