What LED bulb should I use for Sonar LED tailights?
Old 04-16-07, 04:29 AM
sleeper408
sleeper408's Avatar
Default What LED bulb should I use for Sonar LED tailights?
Hey guys, I finally realized how pathetic the light output of the chrome amber turn signal bulbs that come with the Sonar tails actually is in the daytime. I was almost rear-ended the other day because the other driver couldn't see my chrome amber bulb "blinking." I know there are members who have changed that crappy bulb to an amber LED bulb.
My questions are:
1) Should I get the regular kind or "refractor" type?
2) Since these are aftermarket tails, is the bulb # still 7440 or a different one?
JeffTsai mentioned that he actually might have used 1156 bulbs for the rear turn signals on his Sonar tails. Can anyone clarify?
Old 04-16-07, 05:18 AM
JeffTsai
JeffTsai's Avatar
Hey don't use the LED stuff. It's simply not bright enough. If you think the chrome bulb is dim, you will laugh at a LED's output. Just use the silverstars I told you about.
The only LED that can come close to a normal bulb would be a Luxeon Star. They are very expensive LED's and are not used in any of the pre-built LED products you can buy. Just to clarify, A 3w Luxeon Star is as bright as about 40-50 standard LED's. You need at least 3 Luxeon stars and a complex system to diffuse the light correctly to match the output of a single silverstar bulb. Trust me I've tried many combos. Just stick with a normal bulb To use LED's as a blinker requires a complex design and more powerful LED's. This is why even most new cars with OEM LED tail lights still use standard bulbs for blinkers.
Old 04-16-07, 11:42 AM
chrispy
chrispy's Avatar
Anyone want to sell me their chrome bulbs? I'm using a clear white bulb and it doesn't blink amber. I don't want to get pulled over.
Old 04-16-07, 12:17 PM
AristoPra
AristoPra's Avatar
JeffTsai, which silverstar bulbs would these be? I too thought that the chrome bulbs weren't bright enough either and I just couldn't find a set of brighter bulbs. I will have to these ones a shot since you've had experience with them. TIA! ! !
Old 04-16-07, 01:12 PM
sleeper408
sleeper408's Avatar
Thanks for the great explanation Jeff. I will go ahead and get the Silverstar bulbs.
Old 04-16-07, 01:44 PM
Kharizma
Kharizma's Avatar
i have this problem.. i got some LED bulb thing.. works decently at night, but during the day - the output isn't there lol especially wit the sun shining on it
Old 04-17-07, 10:15 PM
sleeper408
sleeper408's Avatar
Can anyone confirm whether it is 1156 or the stock 7440?
Old 04-17-07, 10:24 PM
chrispy
chrispy's Avatar
The Sonar tails are size 1156. Anyone want to spare their chrome bulbs that they don't want?
Old 04-18-07, 02:32 PM
sleeper408
sleeper408's Avatar
Thanks. You can have my chrome amber bulbs when I change them out which will be sometime next week. My car is in the shop. I'll send you a PM.
Old 04-27-07, 03:03 PM
sleeper408
sleeper408's Avatar
I didn't find the Silverstar type in 1156. I only found it in 1157A. Will that work?
Old 04-27-07, 03:07 PM
chrispy
chrispy's Avatar
I believe 1157 is dual filament and 1156 is single so they won't work. I could be wrong, can someone confirm?
Old 04-27-07, 06:21 PM
UZ214
UZ214's Avatar
i used a mirror/chrome pia i will put a part number shortly it was 40$ i think really nice and bright, i even got a white led for reverse..looks hot
Old 04-28-07, 04:44 AM
sleeper408
sleeper408's Avatar
That's what I thought. I know the bulbs are the same size but wanted to make sure. Hmmmm..... I'll have to check PepBoys for the Silverstar 1156 then.
jmoney6
03-17-15 12:38 AM
whytry
11-01-12 02:34 PM
xspsi6
Lighting
04-26-12 07:39 AM
JasonCANES
GX - 1st Gen (2003-2009)
04-09-08 08:34 PM
///MDex
02-21-02 05:46 PM
Quick Reply: What LED bulb should I use for Sonar LED tailights?
