GS430 wont start
GS430 wont start
I was gonna sell the car last month, but then changed my mind.. big mistake. Now the car isn't starting - I turn the key,and it just goes "trrrrrrrr", all the lights are blinking and engine isnt cranking. The battery is fine, because the headlights work.Am I looking at a new starter here?
I know you said the battery ok but did you try to jump it anyways?? I had an IS before but gave it to the wife. I didn't use it for an entire weekend and tried to start it on a Monday. No go. The lights went on and eveything but the engine wouldn't turn over. I got a jump and it started up. For some reason, the Lexus battery isn't that strong. The same thing almost happend to my GS I have now...
Dont bother with optima batteries.
Just use any regular battery. Unless you have a huge demand for power, a regular battery works just fine. The battery is only used to start up the car, not run it. I'm running a duralast battery. Run any battery you like, but for the most part, any would do. Optima is twice as expensive, but is it really worth it on a stock GS? Some people have problems with them, while others done. It's a hit and miss.
Guest
Posts: n/a
Any will do! but find one with the correct side poles. The higher CCA will be best (cold cranking amps) 700 or over is ussually good.
If you have a powerful sound system you might consider a higher
Best bet is check your car by Autozone. They will check the charging system ans install the correct battery.
