RIM experts PLZ help!! axis racing 20x10 +25mm & 20x8.5 +20 mm
Old 04-22-07, 07:28 AM
TonY_G
TonY_G's Avatar
Default RIM experts PLZ help!! axis racing 20x10 +25mm & 20x8.5 +20 mm
axis racing 20x10 + 25mm & 20x8.5 +20mm and will clear BBK
can i put 285/30/20's in the back and 245/35/20's in the front?
This setup is for a 350z, so its a bolt on,
But my main question is I wanna put 285/30/20's instead of 275/30/20's
does the offset affect the tire size i can use? i don't want it to rub
can i put 285's?
Attached Thumbnails RIM experts PLZ help!! axis racing 20x10 +25mm & 20x8.5 +20 mm-1.jpg
Old 04-22-07, 07:29 AM
TonY_G
TonY_G's Avatar
Here is another pic of the rimz
Attached Thumbnails RIM experts PLZ help!! axis racing 20x10 +25mm & 20x8.5 +20 mm-2.jpg
Old 04-22-07, 07:32 AM
carbongs
carbongs's Avatar
+25 is gonna scrub! really bad. i have the exe's on my car now by axis and it is a +35 and still scrubs. had to shave the fender 1/4 inch
Old 04-22-07, 07:36 AM
TonY_G
TonY_G's Avatar
so ur saying the rim will rub or the tire?
so basically go 275/30/20's? on the setup? I want no shaving etc...
Old 04-22-07, 09:56 AM
bighitbike
bighitbike's Avatar
275s? You're going to rub like mad. You need to get some serious stretch to fit these wheels on. We're talking like 235's
Old 04-22-07, 10:49 AM
TonY_G
TonY_G's Avatar
there is no way im going less than 275's in the back bro,
cause i have that on my current setup 19's,19x9.5 & 19x8.5 +35 offset and it clears bbk 275/30/19 & 245/35/19
but im going 20's... and these are great rims
how can a 350z pull off a 285/30/20 rear on a 20+ offset 20 inch rim and a GS can't???????????
so basically its the offset thats killing it? 35+ to a 20+ is very little no? its not like putting on a 15mm spacer? the tire shifts out more...
Whats the problem? i measured my current 19's, i figure... add +1 inch up for 20'' from 19''
and i have currently 275/30/19's so i see how it sits in the fender,,, so 275/30/20 should be more or less the same tire just 1'' up,
please can some1 help me, i wanna buy these rims...
Old 04-22-07, 10:58 AM
bighitbike
bighitbike's Avatar
BBK has nothing to do with offset BTW. It has everything to do with what disk the rims are. G35's and Z's can accept a MUCH lower offset then a GS do to there body style and fenders. You will need a serious fender pull to fit 285's on 20's with a 20 offset. Try to fit them and see what i'm saying. Most VIPer's have 20 offset in 19's with stretched tires so it clears. 20's is unreal especially with 285's
Old 04-22-07, 11:11 AM
TonY_G
TonY_G's Avatar
They also offer them in the 45 + rear and 35+ front,
20x10 and 20 x 8.5 but not sure if it clears BBK though
so on this setup i can do 285/30/20's??? or 275/30/20's now??
let me know plz,
thanx again for ur help
Old 04-22-07, 12:07 PM
sleeper408
sleeper408's Avatar
let me know plz,
This is the size you should get then and run 275/30/20 in the rear. As far as BBK fitment, check with the seller or even manufacturer. It comes down to disk type and spoke design, not offset.
Old 04-22-07, 12:24 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Nice looking wheels... 275 30 20 should be fine..
Old 04-22-07, 01:46 PM
bighitbike
bighitbike's Avatar
let me know plz,
That's what you need. Again BBK fitment has nothing to do with offset, it has everything to do with disk/spoke type.
Old 04-22-07, 03:24 PM
bugeyeGS
bugeyeGS's Avatar
i got those in 19in and trying to sell for 20in's too
Old 04-23-07, 03:21 AM
Neo
The One
Neo's Avatar
As others have said, This setup will rub whether you put 275s or 285s.
No idea with BBK on this setup. 285s should work with this rear setup, though.
Old 04-23-07, 05:49 AM
TonY_G
TonY_G's Avatar
k, here's the deal, i checked, and no i can't get those offsets,
i compared my car lastnite to my neighbours 06 350z, and its a huge difference, lol,
anyways, im getting the more conservative setting of +45 rear and +35 front, but they don't know if it clears the BBK, so a 3mm & 5mm spacer is coming with it just incase
in my current setup the rims are clearing the Supra TT brakes by a hair pin
we'll C, the rims are getting shipped monday,
275/30/20 Rear, 245/35/20 front cause the car is getting slammed, *still, i might need to slightly pull my fenders in the rear depending on how low, but we'll see
and its going to be Falken 452 or Toyo Proxy T1R,
4.5 inch LIP
most likely falken cause its cheaper, but in the rattings its slightly better than Toyo's...
any feedback on the falken 452's b4 i order???
thanx,
Old 04-25-07, 07:32 PM
350forE
350forE's Avatar
I have 245/35/Front & 275/30/20 rear,+ im lowered and im fine
Quick Reply: RIM experts PLZ help!! axis racing 20x10 +25mm & 20x8.5 +20 mm
