oil pan, meet jack!
Old 04-22-07, 05:51 PM
hakes
hakes's Avatar
Default oil pan, meet jack!
Well I will probably win the idiot of the weekend award. I was changing my wheels to put on the summers and the hydrolic jack was misplaced and I bent my oil pan up a bit. It went up maybe 1/2 inch on one side. I do not know anything about the internals of the pan. Am I screwed and need to have this cover replaced?
There are no leaks from the pan - I had my oil changed yesterday (did not check level then, asumed the correct amount of oil was put in. The dippy now tells me that the oil is above the top mark about 1/16.
I am ok to run? Is there some internals in there that I should be concerned with? Thanks for your help, I feel like an ***. I have pictures, hopefully I can post them, I think something is weird with the site right now. 2003 GS3 24k.
Thanks.
Old 04-22-07, 05:52 PM
hakes
hakes's Avatar
Pictures are here, I hope. .
Old 04-22-07, 05:58 PM
GSteg
GSteg's Avatar
You'll be fine, but your readings mine be off a bit (you probably figured that out already).
Unfortunately, a new pan (the one with the drain plug on it) will cost you about $300 retail.
If you're not willing to buy a new one, just go to the junkyard and find yourself a used one and clean it up really really really well.
I can't see the picture, but your pan is probably dented, and not cracked.
And yes, I agree, the location of the crossmember is too far back for most jacks. I hate the design, but what can I do
Old 04-22-07, 06:18 PM
hakes
hakes's Avatar
Thanks Gsteg, that makes me feel better.
Old 04-22-07, 06:53 PM
chuckb
chuckb's Avatar
I wouldn't be so sure it's fine. where's the pics? the bottom end of your motor and the oil pressure are very important stuff. if the pan is bent enough it could maybe hit the crank. or you could've messed up the oil pump or passages etc.
I'm real **** about stuff like this, but you should pull the pan and at least check it. personally I would fix it before driving it.
Old 04-22-07, 07:03 PM
o2GS43o
o2GS43o's Avatar
Ouch, depending on how it looks like... Post some pics of it... Generally if you have a slammed car, your oil pan can get scratched by bumps, etc.,
Old 04-22-07, 11:56 PM
GSteg
GSteg's Avatar
My buddy as a very very low accord and his oil pan doesn't even resemble an oil pan anymore. It's still running. At least it's not leaking
Old 04-23-07, 12:24 AM
Pearlpower
Pearlpower's Avatar
Plenty of room for the crank to still slosh around in there. Only other concern would be the oil pickup. If it is bent or cracked then this could starve your motor and then there goes the bearings.
Post some pics to that everyone can have a better idea.
Old 04-23-07, 04:36 PM
hakes
hakes's Avatar
Here are some pics - I needed to reduce the resolution to post them.
Old 04-23-07, 04:37 PM
hakes
hakes's Avatar
Old 04-23-07, 04:38 PM
hakes
hakes's Avatar
Old 04-23-07, 04:39 PM
hakes
hakes's Avatar
44444444444444444
Old 04-23-07, 04:59 PM
ARISTOh
ARISTOh's Avatar
lol now you have a modded oil pan!
Old 04-23-07, 05:09 PM
e-man
e-man's Avatar
This sounds like something I would do.
Mind you, I know absolutely nothing about this, and what little I do know is probably wrong anyway, but that doesn't look too bad to me.
Old 04-23-07, 05:51 PM
bighitbike
bighitbike's Avatar
If it's not leaking I wouldn't worry about it. Just note that your measurement will be off when checking your oil
Quick Reply: oil pan, meet jack!
