How to gently remove door panel.
If I remember correctly its like 3 phillip screws at the bottom, I think its has one in the mid section and than you have to remove the little plastic cover tha is behine the inside door handle and there is another philip screw behind that one as well. Also actually there is another on the part of the door closest to the dash. once all screws are off just pull the panel upwards and she will clip out.
sallydrive
08-14-12 07:27 PM
