timing belt change
i can't find the diy timing belt change for 98 up gs 300 anymore.if some one still have the site let me know.it show step by step on how to change it i wanted to save $$ any help will be welcome thanks
This isn't really something I'd recommend for a DIY lol. I mean if you're at the level where you can change a timing belt then I can provide you with torque specs and such. However, I would not recommend it if you've never done changed a timing belt before.
Basic guide
-Remove all the plastic covers hiding the timing belt.
-Loosen crank pulley bolt. This one is gona be REALLY REALLY tough to do unless you have the service tool to hold the crank in place.
-Loosen tensioner. It's kinda hidden, you'll have to loosen it from under the car (two 12mm bolts).
-Remove crank pulley and remove the plastic covers behind the pulley.
-At this stage you should be able to pull the timing belt off and replace it with the new one.
-Once you reinstall the new belt, make sure you have the timing set correctly or else you will knock valves into your pistons. If you don't know how to do this then don't even attempt a DIY timing belt job. Take your car to a shop.
-Reinstall everything in reverse order.
Basic guide
Found it, i knew i had it somewhere sicne my dad's lexus is a gs300 and i found it while surfing the web but don't remember where i downloaded it from.
Good luck if you decided to do it your selft....
thanks for all the info.just wasn't to sure but now i have a good idea, i've done plenty of honda b series and h series its like the h series motor it comes with hydro tensioner.i know its not a honda but i rather do it myself, but if it goes bad 2jzgte? i'll let you know how it goes thanks again
mooseboy84
10-31-15 11:35 PM
