wald kit
wald kit
Hey guys i have the wald executive kit on my car and the trimming on my doors are bulging out because of the side skirts. Is there anything i can do or any way to fix it? Ill try to have pic up tomorrow. thanks
i did a test fit before and i knew it's positive that this part will stick-out! so... to keep the clean lines with this trims i just made up a brackets (home depot) and then TOOK OFF the OEM sides! u can use the holes (for the screws-white little rectangular shapes, 6-8pcs. of it ) where the OEM was placed and then put a bracket 1 on the front and 1 at the rear (wheel wells) install the kit (pre-drilled) then attach the nuts and bolts to it, to cover the screws (sidestep) i just bought some wall mouldings (rubberized) then attached it with 3M double sided tape! i wish i could provide pictures at the moment but the camera just gave up couple of days ago, i'll c if i can use my cellphone.
