Acceleration lag....what's the deal?
I'm noticing on my 2GS3, which is fairly new for me, that there is a lag when I accelerate from a stop. It usually occurs around 2000 rpm between 15-20mph, more noticeably when I have the Power mode button engaged. It feels like a turbo lag...you depress the pedal and there's a delay before car begins to accelerate.
Is this normal with this vehicle? It's kind of bothersome. Suggestions or thoughts...? Thanks.
my **** does it to its the oddest **** i can even floor it when it starts to do it and it will not accelerate for a min then it will drop gear and go
anyone else havin this lag issue??????
Mine feels like it's dropping a gear for a split second also. If I stay on the pedal hard, it then lurches forward after recovering from the lag.
I may try some Torque Masters or new Denso/NGK.
Check this thread https://www.clublexus.com/forums/sho...osition+sensor and see if it helps. I know it's mainly about GS430s, but the GS300 also has an accelerator pedal position sensor (which is different than a *throttle* position sensor). Hope it helps.
JB
JB
