Stereo Gurus: What's the Best Route to Run an Amp Power Wire?
I have an amp and a sub that I will place in the trunk of my GS. Before I wire it up, I just want to see where you guys/girls are running the power wire from the battery to the trunk.
Thanks
Thanks
Use an existing wire harness boot in the firewall, poke a hole on the same boot and slip the power wire through. Once inside the cabin, run the wire underneath the door sills towards the trunk.
I ran two 4-gauge power wires down the right side of mine, right through the grommet near the factory battery location. It was a tight squeeze to get the wires through the rubber grommet, then they immediately turn downwards behind the glove box and all the way down the passenger side.
I removed the rear seat to get the wires into the trunk and then ended-up removing the passenger seat to tape the wires down beneath the carpet. The RCAs run down along the center tunnel, in an effort to minimize noise.
Then I got crazy with the Dynamat Extreme...
Stub333
13
05-09-05 09:54 PM
///MDex
12-03-01 04:53 AM
