Mark Levinson Speaker Replacement
#76
^^^That's what I'm wondering now. I'm in the process of thinking of buying the 6.5in speaker baffles off ebay for all four doors and find a free air sub. I want to go ahead and replace all speakers at once. I was running Pioneer speaker off my Bose in my old Infiniti.
#77
Don't understand why anyone doing any kind of upgrade would not replace all of the speakers. When I bought my GS the first thing I did was rip out the whole Nakamichi system. Whatever floats your boat!
#78
OutlawTita- I completely agree with you- I have have so many other projects right now- and being that the GS is my daily driver- It's hard to find a day to remove all the door panels and install a couple nice sets of components into the Lexus, to replace all the OEM Mids & Highs. I'm thinking that IS what I'm going to do though- I want to keep the ML amp in there just to run the Navigation voice...I'm going to use the JL Audio "Clean Sweep" (CL441dsp) along with one nice amp to run the mids/highs and the 10IB4 sub that I'll be installing on the rear deck...
I want to hear back from people who have installed the (old school, and rare- since DISCONTINUED) 10IB4 sub in their 2GS's!
#79
***Just noticed that I don't have the ML headunit...dang! I just have the regular Poineer radio. What tipped me off was people stating they had to replace their center speaker...I didn't know what the heck they were talking about lol. Well I'm guessing the regular amp still should be able to push the new sub.
AirRideFan (04-05-19)
#80
You got to be kidding... Don't waste your time with yet another Cheaply made piece of crap Mark Levinson sub replacement. Get your self a quality Free air sub-woofer. Try JL, i did that and it sound clean and Wwaaaaayyy better than stock...did i mention quality sound. Not sure what Lexus/ Mark Levinson was thinking placing that piece of crap they refer to as a subwoofer.
#81
#82
i ended up using a dremel to cut off the ML sub and drill holes in the housing to fit a CVR 10" kicker sub. had to cut the truck too because the bolts holding the sub into the housing needed fitting. everything works well with the ML stock amp and it hit much harder. i dont listen to music much so its perfect for me and looks clean! i just had to get rid of the busted old ML sub.
now my speakers are starting to cut in and out. great!!!! (sarcastically)
#84
i got a nice impossible to find free air JL Audio 10IB4 with your name all over it buddy. PM me.
*install is cake, basically a drop in after you pull up the rear deck lid and you can power directly off your factory amp. sounds much better then oem sub.
#85
Problem is, now my radio is CUTTING IN/OUT...and doesn't even TURN ON half the time. Mark Levinson amp went bad? WTF...? ha
Lexus is such an amazing brand- I'm surprised they allowed the used of such poor quality (ML) junk to be available in them (as an "OPTION", too!) ha
#86
Aww Crap, my JL has pooped out on me....
Sadly my JL has decided to crap out on me. Please keep in mind i do not crank this thing. The most volume this this has ever received is 25%, Amp is less than 25% Gain. It sounds like its bottoming out at low volume then completely goes away with 40-50% volume turned up... I think i'll replace it with a Image Dynamics free air flow sub at Woffersetc.com.
#87
Bad set up im guess???
You have one? I just bought a "NIB" one on ebay a few months ago... SO GLAD I FOUND IT on there! (it's from 6/96!...but never used/NEW in the box)
My set up:
Sock Mark Lev amp still intact.
Stock speakers all around, minus Sub
Sub = JL 8 ohm free air sub. (does not have to be JL) can be any free air sub.
4 channel alpine amp bridged 2 channel to sub. (not necessary all you need is a mono amp of bridged 2 channel)
With aftermarket amp porwering the Sub you can use a 4 ohm sub(recommended) as mine blew from 8 ohms
#88
I got a JL, see posts below
You dont need a JL, if you are doing a simple drop in, get any Free Air 8 ohm sub. I like the guys over at woffersetc.com
http://www.woofersetc.com/c-33-10-su...ufacturerid=36
Call and ask them for a good speaker for the car they recommend Image Dynamics, which is a much better sub.
Now if you are going to run an extra amp strictly for the Sub while using the stock ML amp get a 4 ohm Sub.
All the best... i try post pics....
