Camber kit?
There can only be One
So does the GS300 have a camber kit?
I just rotated my staggered tires the ONLY way possible and WOW the wear on them on the inside after only like 6 months was CRAZY!
I searched the threads and have not found anything that makes me get any closer to getting this fixed. Is it something that as a Lowered GS owner I just have to live with?
Is everyone that is dropped having the same inner tire wear issue?
The GS has some built-in adjustment on the lower control arms.
My adjusters are maxed as positive as possible and I still have -2.2 front and -2.3 degrees rear.
Nagista is the company that makes the adjustable front upper A-arm and adjustable lower rear arm. I have these coming and will review the fitment on my V8 car (they are listed only for the 6-cylinder model)
With the right alignment shop it is possible to be dropped without having excessive inner tire wear. I would almost put money down that with the excessive wear rate you are getting you may have a toe out condition. Slight camber combined with the wrong toe angle can be a significant contributor to excessive inner tire wear.
Try reading up on my post and the post by DoubleWoosh here: https://www.clublexus.com/forums/sho...=74705&page=10
Did you ever install the Nagisa adjustable front upper A-arm on your car? Did they fit? Any feedback is appreciated!
Thanks,
DJC
I never did. The Nagista parts are available from http://www.more-japan.com/home.php?cat=287 (Tanabe) but for $1600+ installation for the front & rear pieces I figured I'd rather use the money to replace the tires once or twice more, especially now that I don't drive the car that much.
My car has had ball joints & caster arms replaced and numerous alignments, and it still eats tires. I have found that the front wears a little faster than the rear, but it is definitely camber-related as there is no evidence of feathering on the tires.
DJC
1 Post
This all add's up to $5283.00 that's a lot of tires ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
See details Nagisa Auto JZA16 GS300 Adjustable Front Upper Control Arm
Part Number: XN24005
The Nagisa Auto Lexus GS300 Front Upper Control Arm replaces the OEM piece with a much stronger unit with spherical pillowball joints.
Our Price: $990.00
See details Nagisa Auto JZA16 GS300 Adjustable Rear Lower Arm
Part Number: XN24001
The Rear Lower Arm allows adjustments and corrections to camber. Camber may be adjusted without needing to remove the lower arm after installed. For Racing Applications.
Our Price: $655.00
See details Nagisa Auto JZA16 GS300 Adjustable Rear Tension Rod
Part Number: XN24002
Replaces stock tension rods with reinforced units with solid pillowball ends.
May be used for Caster angle changes.
Our Price: $450.00
See details Nagisa Auto JZA16 GS300 Adjustable Tension Rod
Part Number: XN24007
Our Price: $655.00
See details Nagisa Auto JZA16 GS300 Adjustable Tie Rod End
Part Number: XN24004
These pillowball tie rod ends are designed to hinder the effects of bump steer when the front wheels toe out excessively over bumps.
Our Price: $390.00
See details Nagisa Auto JZA16 GS300 Adjustable Toe Control Rod
Part Number: XN24003
For adjustment of toe in and toe out, Nagisa Auto toe control rods allow for fine tuning of the suspension.
Our Price: $498.00
See details Nagisa Auto JZA80 Supra Adjustable Rear Lower Arm
Part Number: XN12001
Our Price: $925.00
See details Nagisa Auto JZA80 Supra Adjustable Rear Tension Rod
Part Number: XN12003
Our Price: $450.00
See details Nagisa Auto JZA80 Supra Adjustable Toe Control Rod
Part Number: XN12002
Our Price: $450.00
See details Nagisa Auto JZZ30 SC300/400 Adjustable Rear Lower Arm
Part Number: XN95001
Our Price: $925.00
Our Price: $990.00
Our Price: $655.00
Our Price: $450.00
Our Price: $655.00
Our Price: $390.00
Our Price: $498.00
Our Price: $925.00
Our Price: $450.00
Our Price: $450.00
Our Price: $925.00
