A/C Problem. Right Side blowing warm air
#31
Registered User
air problem
I just had mine fixed try to fix it myself bought a air controll unit that wasnt the issue why up being a air dampner problem over $900 to fix
#32
#33
Okay.. I think I have a reasonable explantion as to what is going on with the passenger side being warmer.
The heater core in and out lines come in on the passenger side. I think that when the refrigerant charge is low this causes that side to be a little bit warmer.
BTW.. I cannot beleive Toyota put the servos where they did. It is next to impossible to get to the screws that hold the servos on to the evaporator/heater-core housing. What a bunch of idiots. Makes me feel like selling.
BTW.. I got a 22oz can of r134a and it is very cold now... We will see how long it will last.
BP
BP
#34
Common Problem, no difinitive fix yet
If you check out this thread, you'll see a lot of people have experienced this problem and there is still no definite answer. https://www.clublexus.com/forums/sho...ight=darrylg33
Could be lack of refrigerant or servos, or heater core. You have to work through all of them. I actually had to replace my A/C Compressor this year as it died completely, so when I recharged it, I still have pass side a few degrees warmer than driver side when on full A/C, I imagine I will still have cold air in the winter if I don't fix it on the pass side. I'm going to change the servo next, (check the pdf's in the thread) and if that doesn't work I'll go after the heater core.
#35
If you stumble across this in a search go here:
https://www.clublexus.com/forums/gs-...vo-motors.html
that will fix your right side temp problem-as well as your mode/direction of air blowing through the vents problem
that clicking sound you hear behind the dash when you fire up the car and the air is only blowing through the vents/window/floor is the mode servo grinding it's gears...they're shot!
lilscrapy8
07-02-14 02:20 PM
