Yellow fogs
Yellow fogs
I'm interested in changing my regular fog lights into the yellow that some of the second gen have, I saw the yellow housing on ebay for $200, now my question is this a matter of just changing to the yellow housing and perhaps a yellow bulb or are they 3000k HID bulbs too? thanks in advance and I did try to search!
Just buy the yellow fogs and swap out. Bulbs are the same. It's a 5 minute job at most. Just undo the 2 philips screws on the fogs and they slide right out. Kinda too easy if you ask me. That's why I recommend you put on some security fasteners so the common theif won't be able to steal your fogs!
Also, you can probably ask around to see if anyone wants to swap the yellow for clears. Or just check the classifieds to see if anyone has a set of fogs for sale. You can usually get a set here for around $100 or so
found these for you right now. good luck
http://cgi.ebay.ca/98-2004-Lexus-gs3...QQcmdZViewItem
if you really want yellow fogs, i would jump on these as they usually go fo 200+
