how much does a roof spoiler usually run, and can you put it on yourself
A roof spoiler can run you anywhere from like $100-$400+. You can most definitely install it yourself, you just have to make sure you know where it mounts. If I'm not mistaked most if not all use double-sided tape. The problem with installing them is that some mount on the rubber strip on the window and some mount on the actual roof of the car.
