help: wheel fitment
help: wheel fitment
Just wondering if someone could chime on fitment for a 2nd Gen GS300.
19x9 +35 w/ 235/35/19
19x10 +38 w/ 265/30/19
Can i get away with fitting these WITHOUT ANY fender rolling or shaving? I was doing some searching and I believe i could get away with the rears, but the fronts im not 100% sure. Some advice please.
Can i get away with fitting these without and fender rolling or shaving? I was doing some searching and I believe i could get away with the rears, but the fronts im not 100% sure. Some advice please.
reference this article. should help ya out.
http://lgwnorcal.net/articles/index.html#null
Thanks guys!
I can say this, those offsets will fit just fine.
I had 19x10+35 w/ 275/30 tires(toyo) All was fine.
The front is fine. I've gone from19x9(+40,+35,+30 and now +19)
+19 I would say is professional. Going lower than +35 and you will have to roll.
Contact either Got parts? or Rdubz. Those guys roll on some nice offsets.
Northern California Regional Officer
Thanks for the link to the wheel size/offset chart, its really a good reference! However, based on my wheel size and offsets, the chart says that my fitment is "professional"? I don't want to do any fender rolling or shaving. The tire size should help with fitment, but i think i need more feedback.
Thanks guys!
Thanks guys!
+35 or less is professional.
You posted you were at +38, so that's "less" agressive. You should be good.
In general you , but your results may vary, with 5 people in the car and a trunk full of luggage and a low drop, you may stand a chance to rub.
The problem I see with most comments are that people base their possibility to rub on their personal use of the car. Getting advice from someone who drives primarily by themself, or without rear passengers or heavy stereo gear in the trunk, or a modest drop, etc. may get you a different answer than what others have experienced.
The recommendations on the chart on the LGW site, are based on the more challenging conditions of more weight in the car and a moderate drop.
I have some 19 x 8.5 35 mm offset / 245/35/19 tires(front) and some 19 x 9.5 35 mm offset 275/30/19 (rear). I am on the fence as to if this could be a problem. Right now the car is stock ride height, but I may be inclined to put the smallest drop possible. Do you guys think this will give me grief?
Brandon
Brandon
Brandon
Brandon
On a 9.5, +38 is conservative, so +35 is slightly more. Also on a 9.5 a 265 tire is a better fit. This will give you tons of clearance.
You are far from being even close to flush with the fender.
Those members who do inner fender trimming can fit tires/wheels as wide as 305 and 11 inch wide wheels with ZERO rub at any ride height. Your set up is quite conservative compared to that.
Thanks guys!
Thanks guys!
