Who makes OEM xenon bulb?(attn Carson Toyota)?
so is it a big difference? or just a slight difference?
CEO
CEO
Hey guys.....I changed the bulbs using directions I found on here. Think the post was called "instruction for factory hid bulb replacement" or something by a member named shinchan. The instructions were excellent, the install was simple and quick, and I was a bit angry that Lexus has the nerve to charge 110.00 canadian labour for this!!!
Anyway, i put the D2R bulb from my friend in (just the bulb, didn't change ballast)...the light came on at first for a second or two, then there was a zapping or electrical sound and the bulb went out. Won't work anymore. Any idea what happened? Again this is using an Osram D2R bulb from a 99 or so Acura 3.2 TL
Registered User
hey guys.. i just last week had the passenger side bulbs go out.. so what i di was search the net hard for a phillips set of 4300k D2R bulb, and the cheapest new ones i found were at www.autodirectsave.com at $85.99 each i bought a pair so they'd match in color.. if u guys just buy one bulb it may not match... mine right b4 it went out turned purplish pink n flickered then eventually went out... so $180 with shipping total not too bad! here's a link to the bulb
http://www.autodirectsave.com/prod/P...4300K_bulb/113
wtfsajayte
02-21-14 07:09 AM
