Who makes OEM xenon bulb?(attn Carson Toyota)?
Old 06-01-07, 07:48 AM
ZinikGS
ZinikGS's Avatar
Default Who makes OEM xenon bulb?(attn Carson Toyota)?
Hey guys, my passenger xenon headlight for my 98 GS400 recently went out. Lexus quote me about 1500 bucks Canadian + tax for a "headlamp" which I assume is the whole headlamp assembly, which I dont' need, and around 310.00 + tax for the bulb.
My friend has a few xenon bulbs (+ ballast etc.) for a 99 acura 3.2 TL. I believe the manufacturer is a company called Xenarc, not sure about the model number etc. I can get that from him. Does anyone know who makes the OEM GS400 bulb and what the model is? Perhaps one of the members that work at Carson Toyota could help here? Has anyone purchased one before? I know the chances are slim but I'm thinking there's a good chance that several car companies buy their xenons from the same manufacturer and maybe even the same model, then I can get the bulb for free and have lexus install it.
Thanks!
Old 06-01-07, 07:55 AM
gs400 civi
gs400 civi's Avatar
hey, i recently had one go out on me and found a DIY on replacing the bulbs on here just by searching for a couple of minutes and also the part number for the bulbs is D2R and oem is like 45 or 43000k, i got a set of 8000k-blue bulbs for 40 a peice and put them in in like ten minutes. Google the D2R bulb and you can chose who to buy them from, oh and whatch out for the ones that say off road use only, they aren't legal or something, I bought some anyway-way cheaper.
Old 06-01-07, 07:56 AM
RI-Lex
RI-Lex's Avatar
If is only the bulb you need to replaced is a D2R I believe, I have one for sale if you need it $30 shipped, oh btw if your friends acura bulb is OEM is also a D2R
Old 06-01-07, 08:01 AM
ZinikGS
ZinikGS's Avatar
thanks guys this forum is awesome!
will the ballast etc. from my friends 99 TL also work in my GS if its the same bulb?
thanks
Old 06-01-07, 08:09 AM
RI-Lex
RI-Lex's Avatar
the bulb will for sure , not the ballast I don't belive, toyota ballast are slimmer I've heard
Old 06-01-07, 08:16 AM
ZinikGS
ZinikGS's Avatar
hmmm...so lexus will probably force me to buy a bulb from them anyway....maybe i'll try online. The bulb you have, is it used?
Old 06-01-07, 08:22 AM
RI-Lex
RI-Lex's Avatar
yeah its use, only for a few months on my previous car I had upgraded the color to a 6000k, the one I have is a 4300k Osram D2R
Old 06-01-07, 08:25 AM
chrispy
chrispy's Avatar
If a bulb just went out, you need to get a matching set or the color won't match. Get a pair of D2R's from ebay, they're fairly cheap. Maybe around $40-$50.
Old 06-01-07, 08:28 AM
ZinikGS
ZinikGS's Avatar
any way to tell if its the bulb that went out or just some electrical problem? I have heard that before a xenon bulb goes out it turns really pink, and have seen some cars like this. I dont' recall mine going pink, but it used to flicker or cut in and out just before it went out for good...so maybe the bulb itself is ok but there is some loose connection or some other problem?
Old 06-01-07, 09:21 AM
minla007
minla007's Avatar
my passenger side went out for a day or two...then it magically appeared to work fine again....weird...when the pass. side bulb went out, i would turn the heaadlights on/off again and it would come back on.....maybe just loose wiriing
Old 06-01-07, 10:07 AM
GSteg
GSteg's Avatar
Currently, there are two major suppliers (high quality that is) of HID bulbs for automotive use. Phillips and Osram are the two suppliers. Xenarc is a trademark of Osram. The OEM bulb that comes in our car are the Phillips D2R 4300K. You can use either Osram or Phillips in your car, but there will be as light difference in color, probably nothing to complain about if you're getting the bulbs for free.
Most ballast should work in your car. The difference will be the shape/size/thickness/etc. Otherwise they will power your HID bulbs fine.
The OEM ballasts in the GS are 1st generation Denso. They are quite huge anyways.
Old 06-01-07, 11:31 AM
ZinikGS
ZinikGS's Avatar
so i take this to mean that i can use the FREE acura bulb? Awesome, thanks a lot I think I will try it and if it doesn't work out then look online for a GS400 one. Thanks so much!!
Old 06-01-07, 11:42 AM
RI-Lex
RI-Lex's Avatar
dude any D2R bulb doesn't go by make or model
Old 06-01-07, 11:49 AM
THE_CEO
THE_CEO's Avatar
I was looking into this. how much of a difference did you notice between the 4300k and the 6000k?
CEO
Old 06-01-07, 12:14 PM
RI-Lex
RI-Lex's Avatar
more color basiclly, 6000k has more off a blue tint to it, 4300k has a brighter light lumen on the road than the 6k
Quick Reply: Who makes OEM xenon bulb?(attn Carson Toyota)?
