my car doesn't pull off the line...
You have to take out the throttle body assembly to thoroughly clean the front and back of the throttle plate.
As for the MAF, get yourself a can of CRC Mass Air Sensor cleaner. Should be about $3-4. Gently spray it in the MAF opening and it'll self dry (evaporates quickly). The MAF itself is located on top of the OEM airbox. It's the small module with a connector on top of it. You can't miss it
https://www.clublexus.com/forums/sho...=throttle+body
I'll have to read thiss thread in the morning, but seems like half way down the first page, it starts with some advice that might work.
Here is DIY for throttle body cleaning from archive...
https://www.clublexus.com/forums/sho...+throttle+body
(1) Take off the engine cover. There are 2 10mm bolts and 2 10mm bolt caps holding it in place.
(2) Once the engine cover is off, you need to take off the black box immediately to the left of the engine (as you're looking at it). The air intake tube coming out of the filter box and going into the throttle body is attached to and a part of this black box. First, take a screwdriver and loosen the clamps holding the air intake to the filter box and to the throttle body. Second, remove the 2 bolts that are holding the black box to the engine (one is in the back and the other is on the left side). Third, remove the 3 vacuum tubes that are attached to the black box. The vacuum tubes are attached to the box with pressure clips. Just squeeze the clips and pull off the rubber tubes. Lastly, remove the air intake tube from both the filter box and the throttle body. The air intake tube is accordian-like where it attaches to the filter box, so it comes off pretty easily. I had to apply a little force to remove the air intake tube from the throttle body.
(3) Take your can of throttle body cleaner, spray it on a rag, and wipe away. I also used a toothbrush to scrape away some of the gunk (per Gunru-GS4's suggestion). In fact, the toothbrush came in handy because I was able to wedge it into the throttle body to hold the butterfly cover open while I was cleaning. Some people say you're not supposed to spray throttle body cleaner directly into the TB, but my tech told me it was not a problem to do that. The only part you really need to clean is the butterfly cover and the part of the TB in front of it (towards the front of the car).
(4) Once clean, put everything back together in reverse order.
Like I said, I'm looking to clean up the MAS and throttle body. When I blip the throttle, I get no response. I have to push the pedal about 2/3 the way down before it registers. I'm hoping that the above cleanings take care of it.
i can't spin my tires either. i have 19x9.5's w. 275 series tires in the rear lol when i had my stockies on i had no traction through 3rd lol
so is something wrong with my car or... is it just the wheels?
