my car doesn't pull off the line...
Old 06-05-07, 10:04 PM
  #46
gobears
gobears's Avatar
Gear oil is where Redline make their name.
Expensive....
Old 06-05-07, 10:36 PM
  #47
whazzzzuup
whazzzzuup's Avatar
Originally Posted by GSteg
I have local autopart store that sells it. your local store should have Mobil gear oil in stock. Amsoil and redline can be purchased online. The difference between them all in performance is neglible.
How much should the Mobil gear oil cost? Should be less than 10 dollars a quart right?
Old 06-05-07, 11:02 PM
  #48
GSteg
GSteg's Avatar
yup. Even amsoil and redline was about $8-9/qt
Old 06-05-07, 11:13 PM
  #49
gobears
gobears's Avatar
I just bought 2 Mobil1 for $19.16 from autozone...
Where did you get redline for $8-9?
Old 06-05-07, 11:55 PM
  #50
GSteg
GSteg's Avatar
Super Autobacs. I dont know if they have the same price anymore
Old 06-06-07, 05:14 AM
  #51
rwheelz
rwheelz's Avatar
FWIW, on stock 16s my 99GS4 will smoke the tires by merely pressing on the throttle. With 17's and much bigger/stickier 245 rear tires, it won't spin them in the summer heat at all unless I force it for a split second with the brakes. I think it is just a combo of big heavy wheels and heat.
Old 06-06-07, 06:01 AM
  #52
Rock-a-Lex
Rock-a-Lex's Avatar
Gobears, I just turned 90K miles.
Maybe my diff. fluid is like tar such as what GSteg mentioned earlier...perhaps it has NEVER been changed for the life of my car!!! If that's the case and the diff. fluid is like tar would that be a direct result of performance loss AND terrible fuel mileage; I get 15.5mpg on a babied tank (60%-city/40%-highway)!
Old 08-11-08, 01:40 PM
  #53
VipDout
19x11.5 -51
VipDout's Avatar
Originally Posted by whazzzzuup
Never mind. I found it. It was originally posted by GSTeg. Thanks, man.
I let my friend borrow my camera, but the DIY change is even easier than a regular oil change. It's really easy. When you're under the car, take a look at the passenger side of the differential. There should be two star/hex bolt. I dont remember the exact combination, but there should be a lower and an upper bolt.
Tools Needed:
- (2) quarts of fluid, but you'll probably end up using 1.5 quarts
-Hex/star key. You'll need a somewhat big one so make sure yours fit before you start. I had to run out to my local autopart store to buy the key.
- Any type of pump where you can draw fluid and then inject the fluid. A siphon pump will not work (I tried, very messy result). Turkey Baster works perfectly fine!
- gloves
Basic Steps:
- Jack up the car
- Unbolt the lower bolt, which the differential fluid will drain down from
- Tighten the bolt back up
- Unbolt the upper bolt, which the differential fluid may be filled in.
- Take your pump and fill it up with differential fluid. Pump the fluid into the upper bolt.
- You'll know that you've put enough once the fluid starts to leak out of the upper bolt, and when it does, tighten the upper bolt.
- Lower the car
- Wash your hands
- Take a test drive
- Report back here
Warning: Gloves will come in handy. Differential fluid is probably the worse smelling fluid that goes into our car. Take a sniff and you'll know why .Having one of those orange hand cleaner will come in handy.
Bump for an Easy DIY ! great write up
Old 08-11-08, 05:34 PM
  #54
aristo2369
aristo2369's Avatar
Post diff oil change
Tools Needed:
- gloves
Basic Steps:
- Jack up the car
- Lower the car
- Wash your hands
- Take a test drive
- Report back here
i have a kazz lsd on my gs400 but i dont think the instructions apply since i went under the car and saw only 1 big hex bolt at the bottom/. i do need to change my lsd fluid, from reading i got the redline fluid.
Old 08-11-08, 06:05 PM
  #55
TLW
TLW's Avatar
I have a 74 Blazer I did work on in the rear and got gear oil all in my hair and clothes. To this day I'm traumatized by the smell.
Old 08-11-08, 07:17 PM
  #56
GSteg
GSteg's Avatar
You probably saw the drain bolt. The refill bolt is located further up, and further in towards the main driveshaft. It might be covered in dirt, but it's there.
Old 08-11-08, 07:19 PM
  #57
aristo2369
aristo2369's Avatar
If you're using the OEM housing, then the bolts should be there. How else are you going to drain/refill
well, i looked and found the plugs. my kazz lsd clanks when cold wheny ou make a turn so i hope this help a little to take the noise away
IonSpray35
12-13-11 08:22 AM
IS350atWOT
IS F (2008-2014)
04-12-10 08:34 PM
mrduck
IS F (2008-2014)
15
03-31-10 08:11 AM
pitmanr200
04-04-08 06:11 AM
TruPlaya26
08-20-07 12:26 PM
Quick Reply: my car doesn't pull off the line...
