Check Engine & VSC / VSC lights on! Help
Aloha everyone. I just installed an SRT intake on my 99 GS300. I test drove it for a good 40 miles last night and it was fine. Today on the way to town as I was accelerating to get on an on ramp the check engine light came on as well as the VSC & VSC off lights came on. I had no throttle response at all unless I floored it & then it was minimal. I pulled over & turned the car off & on a few times. I got throttle response back but the lights were still on., but it drove normaly. I managed to limp my way home about 20 miles. As I got closer to home, the car lost throttle response again, & the idle raised to about 2000 rpm, but the car seemed as if it woudn't shift. I manged to get it home top speed around 35 mph. Anyone know. I checked all of the connections & they are all good. Does anyone have any ideas what the problem could be? Has anyone with the intake have a similar problem? Thanks in advance for the help!
mine had the same problem, i took it to the dealership and the codes told them that i needed a new throttle body and sensor, cost me a lot of money
I got a 99 GS4. Same problem. Is does seem to fix itself, although not permanently. The first time it happened, I had the codes read and it was the Throttle Position Sensor. Which was then replaced. Ran fine for a while then it happend again. This time I cleaned the MAF sensor and the throttle body and the problem went away again (for a while). Now just the other day it happened again, this time when I had the codes read, it points to the Accelerator Pedal Position Sensor. I have odered the APPS and it should be here Monday or Tuesday. (Thank god for extended warranties!) I will let you know if this FINALLY fixes the problem.
BTW I have 80K on my car and also have an intake
What intakes are you guys using? I at first was worried I screwed up with the ECU wiring but I double checked everything & its all tightly connected & soldered.
Were you able to clean it? Or did you need to replace it? My Tacoma's MAF when dirty mostly had an erratic idle. I'm not sure what to use or how to clean this MAF. Any tips?
Goldmember
You're in luck as someone else just posted a thread about how to clean the MAF sensor.
https://www.clublexus.com/forums/sho...d.php?t=285675
I've been planning to & I believe that this just pushed me over the edge to buy one. Its the first time the CEL hasn't cleared out on its own. Then again the GS isn't exactly the most basic thing out there. I'll do some research on it.
