Time 2 Do Timing Belt Gs400!!!!
Hey guys, i'm due for a timing belt + water pump change,
just curious, where did u guys locate all your parts.. and i don't mean LEXUS.
what is exactly needed? can some1 write the list for me?
how many hours labor??
I know i need 1 Timing Belt, 1 Timing Belt Tensioner Bearing & 1 Timing Belt Idler Bearing, water pump, what else?????
i see a kit on e-bay, but i mean, i don't trust that stuff,
thank you in advance,
just check ebay for the parts list and go through a site vendor for the discounted toyota parts.
i'd start with:
http://www.l-tunedparts.com/index.php
http://www.lexus-parts.com/
a phone call may be necessary.
i'd start with:
everything and every service is done...
just put denso's in, going 2 do injector cleaning 3 step run-rite ...
just need to the the timing belt,
just need to know how much for parts, and what are all the exact parts, besides what i mentioned above, or is that all?
ya i guess i have 2 make some callz, but i was wondering if some1 could give me a price range and parts list etc.. b4 labor, cause i have a place to do it..
Timing Belt
Water pump
all the O rings
bypass hose
Acc. Belt Adj. Pulley
Acc. Belt Tension Pulley
Accessory Belt Tensioner
Radiator Cap
Timing Belt Adjuster
Crank/Cylinder sensor
Crank Seal
Upper and lower radiator Hoses
All heater hoses
Thermostat & Seal
All belts
New Hose Clamps
Water pump
all the O rings
bypass hose
Radiator Cap
Crank Seal
All heater hoses
Thermostat & Seal
All belts
New Hose Clamps
Timing Belt
Water pump
all the O rings
bypass hose
Radiator Cap
Crank Seal
All heater hoses
Thermostat & Seal
All belts
New Hose Clamps
Water pump
all the O rings
bypass hose
Radiator Cap
Crank Seal
All heater hoses
Thermostat & Seal
All belts
New Hose Clamps
and here i thought it was a few things, lol
is changing the radiator cap and hoses necessary?
Its a pretty heavy job.. I just had my 97 ES done and the O-rings were shot at 85k.. I think its more involved than we think.. For big jobs like this leave to the professionals.. GL and keep us updated.. i have a 400 also so i'm curious on the prices..
Thanks
TF
Thanks
TF
ya your right, well, its going to get replaced at my boi's shop and he knows his stuff...
installed my coilovers etc. installation is not what im worried about,
I wanna know how much bottom line for parts etc..
I see a set for the belt, tensioner, pully for 89$ on e-bay,
water pump i saw 89$ on e-bay,
the rest i have no clue
Timing Belt
Water pump
all the O rings
bypass hose
Radiator Cap
Crank Seal
All heater hoses
Thermostat & Seal
All belts
New Hose Clamps
Water pump
all the O rings
bypass hose
Radiator Cap
Crank Seal
All heater hoses
Thermostat & Seal
All belts
New Hose Clamps
if your window on the drivers side door had a crack. would you replace the glass, window rails, motor, switch, wire harness ect...
