Need help with JDM Visors install
Trying to install Jdm Visors and cant figure out if the metal clip on the actual visor goes over the rubber piece on the door or do i need to pull that rubber out and install the visor first.
Any help would be appreciated!
Thank you!
P.S. I am not sure if this explanation was clear enough. Let me know.
Thank you!
i did mine over the rubber piece, im not 100% sure if thats the right way but it fit and my windows roll up just fine... a couple things though.. with the ones for the front be sure to line up the part that contacts the side mirrors first, and remember that 3m tape is no joke, once its on its on and hard to move
Anyone else wants to chime in?
visors
In order to install ur visors u have to pull out the rubber around the window. Its not that hard, then u push the clips in and pull the tape. After all that just push the rubber back in, make sure its all back in the grooves or ur windows wont roll up. its real easy.
that is waht i thought too, but just wanted to make sure
Thanks again
Egor
