Calling 98-00 Owners w/LED Tails. Help!
I just received the snowflake style tails for my 98. Everything was going smooth with the install until I get to my reverse light. The cutout for the reverse light on the LED tail is much smaller then my factory piece. I call the company I purchased these from, and after sitting on-hold for 15 minutes, someone gets on to tell me that they have never heard of this problem and there should be no difference between the 98 and 01+ factory bulbs. I emailed a fellow member here who has these lights. Apparently the 01+ have a smaller reverse light. Has anyone with a 98-00 purchased these tails? If so, what did you do about the pieces not matching up? Can I just splice on a connector from an 01?
Here is the light...
The smaller outlet I am talking about can be seen to the left... Thanks
I am sure I can, but I am a little annoyed that I was not informed of this. I was told these are plug and play. No one asked what year this was for. I told them GS400, not 430. I'll get it figured out. Maybe I can get the actual original seller on the phone today instead of the guy from yesterday who was telling me the bulbs are no different from the 400 to 430 Thanks for the info everyone
Hey PMIRO2. I had the same problem with the same exact taillights. I didnt feel like going through any more hassle trying to get a harness...so i just borrowed my pops dremel. I made the reverse light hole big enough to fit the bulb n socket. It worked perfectly. Just make sure u get an air compressor or something to try and blow out the the plastic dremel debree that it will leave inside the taillight when u enlarge it.
It worked great for me. let me know if this helps.
it will fit snug. just make sure u only work one spot of opening. for instance...dont go around in circles trynna open up the whole opening. just do one area, and make sure you keep the pre-cut indents in the opening. that way when u put the bulb in, you can still turn it to the right or left until it locks in.
hope this helps, its kinda hard to explain without pics.
