Pictures: GS400 timing belt parts and part #'s. How-to soon.
The timing belt has been replaced, along with the other things. The entire process took 10 hours, with a few minor problems along the way. A how-to will be posted soon, when I have more time.
The car drives great! It is smoother and quieter now. The belt had at least 20K miles left of life on it.
Here is a picture for you guys. The new timing belt and waterpump have been installed in this picture. A lot of the pulleys, covers, radiator fan, accessory belt, etc., are missing. It was the being steps of reinstallation.
A lot more pictures were taken, and will be posted soon.
![](http://i61.photobucket.com/albums/h69/whazzzzuup/IMG_9617.jpg)
First of all.Awsome picture. I love it when folks do stuff on their own. NICE!!! What kind of problems??? I have done a 2uz non VVT.
How hard was it to line up the timing marks? I am having trouble seeing the timing mark on the left hand side. I knowI had trouble getting the damper pulley bolt was hard for me to get off of my timing belt replacement I did.
Again.... NICE BP
Again.... NICE BP
I bought the wrong silicone to seal the water pump to the thermostat (not pictured). So coolant was slightly leaking after warm-up. I found some silicone (in my drawer!) that was made specifically for the waterpump/thermostat area (glycol resistant). That took an extra hour and a half.
First of all, I would like to say that the timing belt change is hell compared to the timing belt replacement on our Lexus/Toyotas. It is so much easier on the Lexus. I think there is a design flaw with the Honda tensioner pulley.
Marking everything before removal is key. Making sure the gears do not move is the most important.
Here are some more pictures for now.
TDC on the camshaft gears.
![](http://i61.photobucket.com/albums/h69/whazzzzuup/IMG_9616.jpg)
![](http://i61.photobucket.com/albums/h69/whazzzzuup/IMG_9615.jpg)
Mirror to see if the belt/gear is in the right place on the crankshaft gear.
![](http://i61.photobucket.com/albums/h69/whazzzzuup/IMG_9583.jpg)
Before and after cleaning of the inside of the camshaft gears/timing belt cover. All the back is the rubber from the timing belt. The area is sealed off from the outside environment.
![](http://i61.photobucket.com/albums/h69/whazzzzuup/IMG_9626.jpg)
I bought the toyota sealant.. they called it like gasket inplace or something.. I did mine on a 4.7 L Tundra.. I wish I took pictures when I did mine.
I hope you took a lot of pics.
So tell me was the right side hard to get lined up on the timing marks on the belt ? I just do not see the marks to line it up.
Did the timing gears move when you took the original belt off? Did you have to disconnect somthing so that the VVT did not move?
B
B
B
B
