Door Lock Acutuators DIY ???
#376
It wont save much trouble if you find the part your need. Replacing the cap that contains the brushes is not too bad. Just be patient and you'll be fine. Eventually your other door locks will die. When you add up the total cost, DIY seems to be the way to go. Then again, your door lock actuator is currently dead...if you can't fix it, buy a new one anyways but at least try. You'll be glad that you did.
#379
Well my drivers door went out last week. So what I did is order a new actuator from Sewell ($200) and the motor from ebay ($15). I will replace the whole actuator, since its the drivers door and I wanna fix it fast, but I will keep the old actuator so I can figure out exactly how it works, so if anymore actuators go bad, I'll just replace the motor.
#381
I just did this replacement and it took me around 40 minutes total from start to finish. Very easy job, and about 10 steps of this tutorial can be skipped, you dont have to remove the mirror, or the glass, or the speaker, and anything that has anything to do with any of these items. Just pop the door panel off, unbolt 3 bolts that are holding the handle, unbolt one bolt that holds the bottom of the window track, unscrew the four T30 screws, and take the actuator out. Very very easy.
To the guy that said he couldnt get the T30 bolt on the inside of the door out - yeah that one was properly stuck. I was however easily able to take it out by grabbing it with a big visegrip.
#383
Och can you go into a little more detail about how you did it, like step by step. If you found a way to do it that is simpler then what I have been reading and everything worked out I would prefer to do it your way because it sounds like a nightmare from reading other peoples steps.
I still would like to try to fix the actuator motor myself instead of ordering a new whole actuator unit but unfortunately it seems fixing the motor does not work out all that great from what I have been reading and they don't last long after working on it and putting the new motor in.
#384
if the motors are installed properly, then it will last just as long, if not longer than the stock motor. Most problems are due to installation errors, not the motor themselves. I have at least 1000 locks/unlocks so far and it's still holding up fine. In fact, I've done at least 10 GS and every one of them is still going strong.
#385
Just make sure you do the procedure with the window all the way up. When you open the door panel, you'll see how simple it is.
As far as replacing just the motor, I wouldn't. Cutting up the plastic case, gluing it back together, etc is just ghetto. Its a Lexus afterall, not a Huidai. And like I said, you also regain that solid "thud" door closing sound, so that alone is worth it.
#386
It is very simple, really. Follow this DIY to remove the plastic door cover panel and disconnect all the switched, then skip everything that has to do with the window. After you've removed the plastic panel, just remove the plastic film on the inside (unglue it carefully without ripping it. Then remove the four T30 bolts, remove the three bolts that hold the handle, and remove 1 bolt that holds the bottom of the window track. Thats it, now you can just pull the handles, disconnect the cables, remove the old actuator, and put the new one in.
I know cutting up the case and gluing it back together is ghetto but unfortunately it seems like the best way to save a bunch of money for this known design defect. My passenger is dead, rear passenger is off and on, a couple times my driver side did not unlock/lock recently. Since Toyota did not know how to design a door lock actuator that would last on the 2nd Gen GS and charges way too much just for a plastic piece with a cheap motor it makes more since to spend around $20 on just the motors to try to replace a couple failed/failing actuators then spending $350-$600 on the actuators or worse using the dealer and paying $1500
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#387
#388
Removing these bolts as you mentioned is the next thing I need to do. I believe these bolts are the ones holding the plastic housing which is white in color.
Still, I don't believe my problem has anything to do with motors like everyone else here in the thread has mentioned. Just a cable out of place hopefully.
#389
i actually on changed the brushes. on 3 i took the old motors cleaned them out then took the bottom with the brushes out of the new motor and put it on the old motor. on one i had to use the new motor and remove the metal thing with a blow torch and switch them. all the motors work fine, the only problem is two of them are locking in the opposite direction.
#390
Has any one tried to get a list together to show which motors go in which model / year lexus and whitch tip should be used. I have herd of FC 280PT-22125, FC 280PC-22125 and a FC 280SC-20150 ... for tips there is a Brass tip 4mm Round with 3mm flat, a long black 4mm with 3mm flat and a star tip. If this list exist could some one point me to it?
I am thinking this might have something to do with the reverse rotation.
