Door Lock Acutuators DIY ???
Old 01-18-10, 01:51 PM
  #436
sfrhack
sfrhack's Avatar
Ready to tackle this DIY. Anyone have any motors left before I order it from ebay?
Old 01-18-10, 02:38 PM
  #437
English66
English66's Avatar
Originally Posted by jimbonuttz
take your door panel back off and check the clearance/space of where the manual door lock is...perhaps something is in the way and not allowing the manual door lock to turn over completely
with the door panel off stick your key in the key hole and turn the key as you look inside the door panel to see if you notice anything
I will try that but I do not know much about door locks. The key turns both ways but nothing happens, no resistence. That's why I am asking before I go to the steelership or a lock shop.
Old 01-19-10, 11:53 PM
  #438
tommyLS460
tommyLS460's Avatar
It's about time I search for this DIY..3 out of my 4 doors are messed up...i can't get them opened with my remote nor with the door lock button thingie...they don't respond...I mean I can still open and lock manually with my key blade...i've been doing that for a year or so now...kinda getting tired of telling people to lock my doors manually and such...I feel embarrassed too...it's not so Lexus style...anyway....so does that mean that I need to replace the actuator thingies?...can anyone tell me exactly what I need to buy?
I also have a few more problems:
1. my heater sometimes blow out cold air instead of hot air
2. my cup holder console in the rear passenger seat is stuck and don't slide out because my little nephew managed to get a few coins stuck in there, I can't seem to see how I can open it
3. some of the lights in the instrument panel (radio/temperature panel) are not on, for example the windshield and the back window is not lid, is that a fuse problem?
Wow! I didn't think my car has that many issues. Hahaha. But I still love her!
Any help with any of the above problems would be appreciated!
Thanks a lot in advance!!
Old 01-20-10, 10:48 AM
  #439
slickgt1
slickgt1's Avatar
did you ever take the actuator out? If you did, someoone missaligned it and the cylinder does not strike the actuator dissengage. I would take it out and check everything.
Old 01-20-10, 10:53 AM
  #440
slickgt1
slickgt1's Avatar
By the way. For those that are saying that the DIY works 50% of the time, just don't know what they are talking about. I posted on page 9 of this post, in 2007. The DIY fix is still perfect. No problems, and saved myself over $800 in parts alone already.
Old 02-20-10, 06:00 PM
  #441
jonIllest
jonIllest's Avatar
i just changed all 4 actuator motors today using this write-up...it took about 5 hours to do them all. big thanks to everyone who shared info!
Old 02-22-10, 08:58 AM
  #442
slickgt1
slickgt1's Avatar
So which motor part number did you use? Please update this thread. Thanks.
Old 02-22-10, 06:58 PM
  #443
jonIllest
jonIllest's Avatar
Mabuchi FC280PC-22125
i bought mine from this seller:
http://motors.shop.ebay.com/rdlawren...1&_from=&_ipg=
Old 03-01-10, 09:11 PM
  #444
anuadu
anuadu's Avatar
A BIG THANKYOU TO TRD911
Just followed instructions from this thread, brought the motor from eBay and with few fiddling around now both front doors on my RX300 1999 now working like charm
Old 03-02-10, 01:15 AM
  #445
GSteg
GSteg's Avatar
Holy smokes they raised up the price on the motor again?? $24 shipped a pair??
You use to be able to buy about 4 motors or so for $10 shipped
Old 03-02-10, 06:25 AM
  #446
slickgt1
slickgt1's Avatar
LOL, was thinking the same thing. Glad i bought 12 back in the day.
Old 03-04-10, 08:38 AM
  #447
Vlad_Stein
Vlad_Stein's Avatar
Yes... Another "Thank You" for TRD911 - I probably would not have attempted this without your efforts.
Just replaced a front passenger door actuator on my GS.
I did make two expensive (in terms of time) mistakes, though (related to each other). I wanted to share them here, so that others have a chance to avoid them.
1) The first and most important was not to look closely at how the lock assembly was put together before taking the actuator casing out. This resulted in putting the casing back in not quite "correctly". It looked good on the surface, but did not work - the door would not open after being shut. I nearly crapped my pants when I shut a naked (inside) door and it would not open when I pulled a handle. I eventually opened it by holding a key in the lock in "open" position, while pulling on the door handle, though.
2) Because it did not work correctly, the interior door lock would not close (physically). So, I decided to "help" it by forcing it and broke the plastic cable attachment to the door panel. I would not have made this mistake if I did #1 right (forcing it didn't help either). Without this attachment, the interior door lock switch will not function. Epoxy did not work (too little surface area - broke off twice), but, luckily, I mended it with garden hose patch tape and gently hammered it into its place on the door panel.
My advice to newbies that want to do this job but are a bit intimidated would be: don't be afraid, but do test the way lock assembly works after taking it out of the door but before taking the actuator casing out of the lock assembly. Before testing, disconnect power connectors from the lock assembly so that your car alarm does not go off. The way to test is to use a screwdriver to "close" (equivalent to shutting the door) the lock (the metal part that catches the latch on the body. Then pull on the door release metal rod and the lock should open. Do the same thing, but now pull on the interior door release "handle" (cable) and you should get the same result. Then lock and unlock the the lock assembly (first with the exterior lock metal rod, then with the internal "switch" (cable). It should work, of course, right after you take it out. While you do these maneuvers watch closely how the actuator casing is connected to the rest of the lock assembly when it moves as a result of the locking and unlocking. This way, you will know how to put it back together correctly. Also, test the assembly after you replace the actuator and put it back together. After mechanical test is done successfully, you can hook it up to power connectors in the door and test out that the new actuator works (what you do is lock the assembly manually, close the lock, then press the open button on the remote. You should hear a click from the assembly, and if the lock opens after pulling on the door release handle then you're good). Only then, epoxy the actuator casing closed and put the thing back together. If you do it like that, it is a piece of cake job - you might spend extra 20 min on the testing but it will save you a lot of headache later on.
Also, I found a way to take off the coupling from the motor shaft without the special tool. Get a pair of pliers - they have a flat blade part that is used to cut wire. So, what you do is pretend you are going to cut the motor shaft (so that the coupling "hides" behind the wire cutting metal part of the pliers). Then, you lay the pliers on some flat hard surface, coupling down, motor sticking up in the air. Then, while holding the pliers with one hand (closed), you use a crow bar or a hammer (the feature to pull nails out) to pry the motor shaft out of the coupling.
I spent a lot of time (I am ashamed to say how much) to fix - due in whole part to not following "an ounce of prevention" approach, but if another actuator goes it would take me ~1.5 hours to do the whole thing.
For the record, this is my first job of that nature (interior panel, electrical things). I don't do anything beyond oil, transmission, differential fluid changes and spark plug replacements by myself. Two exceptions would be this and the lower ball joints replacements. I am no mechanical genius - I can tell you that. The $ cost to me was ~$30, including epoxy, locktite and a T-30 wrench attachment I had to buy.
Good luck and happy fixing.
Cheers!
Old 03-07-10, 08:36 PM
  #448
nguyengs42
nguyengs42's Avatar
Hey Thanks For the DIY! Saved a bunch. Well theres a shortcut to this and some steps can be avoided i just did my front passenger side and it took about and hour or less. If anyone would like, I can make a video and post it on you tube when i do my driver side door next week (just pm me). Just bought a 2pak motor from a fellow member and waiting for shipping. And also btw a motor gear puller come in very handy.
Old 03-12-10, 04:48 PM
  #449
buggs384
buggs384's Avatar
this thread was fantastic. I used the DIY to replace the actuator in my LS 430, there were some differences but mostly the same.
Old 03-24-10, 09:42 PM
  #450
doe619
doe619's Avatar
wow..dont know how old this thread is but i just wanted to say i saved about $600 by doing this DYI.....took a couple hours but all the doors work awsome! THANX
Quick Reply: Door Lock Acutuators DIY ???
