Door Lock Acutuators DIY ???
#676
UPDATE TO DIY: You do not have to take the window or window trim or speaker out. After you take out the door handle, plug the window switch back in and raise the window and then unplug it back. On the lower part of the door, close to the inside T-30 bolt(circled in blue) you will see a 10mm screw(circled in red) for the lower window track, take that out and just move the track to the side out of the way. Now take out the other 3 T-30 bolts that hold the acutuator on and unplug the 2 plugs and pull it out. That's it, now do the reverse and put it back in.
#677
i have a question if anyone ever had this problem or can think of reasons why, that would be very helpful because i'm stomped. I've tried to remove and reinstall, tried to unplug individual actuators on individual doors but same problem still, i have repaired 3 of my actuator like this on my 300 and everything ended up fine, but when i done my friends gs400 today all the doors lock fine, but when it comes to unlocking they unlock fine but the actuator would go through a second cycle of unlocking like a second right after, would that be programmable? or is one of his door modules shot? ohh and when i try to unlock his door with the key it only unlocks the driver's door on first unlock and if your unlock again the passenger doors don't unlock, which is also weird. Any help would be greatly appreciated but tested every single door with the actuators unplugged thinking maybe one of them was causing it to unlock? but i couldn't narrow it down.
#678
#679
#680
It sounds to me that one of the motors is not working or not working good enough to fully lock one of the doors since the car thinks one of the doors is still not locked it Is trying to relock that door. My gs400 used to due that untill I fixed the motors and now it just locks once.
i took the actuators off one at a time in order to try to break down the problem but it still did the double unlocking and it's exactly like that doubling unlocking like how it would double lock or unlock if the module thinks that the command wasn't fully pulled through, but all the doors lock and unlock smoothly? and very powerfully now with the new motors installed and i tried to troubleshoot them one at a time and i couldn't get them to not at anytime double unlock even testing one at a time on the door, which after thinking about it i was really going to point at either door module or maybe master control? really stomped
#681
You know that and I know that, but people who read DIY do not know. If you read the DIY, he tell's you to take off the window trim, window, side view glass, and speaker. The first word in my reply was UPDATE. to let people know there is a better way. Please learn to READ before typing
#682
#683
#684
No problem, we all good. Just was trying to look out for the other members who might be scared to do the DIY
#685
when i tried to check each door individually yesterday, i had all the door panels off while doing the troubleshooting so thats out of the picture. I'm really starting to think it's either both the front doors becasue i don't recall it doing that when i tested the rear and i did the rear first. But i guess if thats not the case it's most likely the door module. ohh yeah on more thing does anyone know how many times that clock spring is suppose to be whined up? i tried to remove the casing back out to see if it was getting jammed on the inside of one of them and the wheel/gear thing spun out i put it back in and spun it twice and it seems like good enough tension for it. lol did anyone also spun out the clock spring? i think i've read that slickgt or trd or someone did that in one of the orignal posts but im not sure if their still around here anymore. thanks but keep them coming! i aint giving up until someone points fingers at teh modules, prolly going to check them all again this weekend if it's nice out.
#686
Does anyone knows how this goes?
I opened my driver's side door on my GS and when I was taking the little motor out this round gear with the spring came off and I have been trying to put it the way it was with no luck. Without it in the right position the door will not open. Does anyone know how to put the little spring with the gear back on?
#687
So front and rear are using the same motor (FC 280PC 22125)? There's no difference between front and rear. My front driver and rear passenger are bad, so I want to by both at the same time. Thanks in advance.
I did my rear pass side door Friday afternoon. Only one razor blade mishap while slicing the case open. Added bulb grease to the contacts, getting the indexed piece off the old motor proved hardest part for me. I used super glue to put case back together, being careful not to get glue on the worm gear.
thanks for the info!!!
#688
#689
i just finished with mines.i got all 4 done!!! and also changed the handles and installed my chrome ones. and everything is good now> im at pro at it. thanks to all of those who actually took the time to transfer the info to all of the CL member. great review now to the car wash. by the way i got oem white dooor handles and trunk bar for sale now lol
#690
sucks!!!!!!! My passenger door's lock JUST stopped working!!! I knew something was wrong when my lights was flashing when i tried to lock the door. damn it!
I just saw a video on youtube...if it details that much effort, I will just reach over and lock my door sheesh
