GS430 stumbling.. help!?
Old 07-02-07, 09:46 AM
slickgt1
slickgt1's Avatar
This might be a funny thing, but do you have fuel in the car? Maybe it leaked out or something. The sputtering and running for a second are symptoms of fuel running out.
On another note, there is something else you can check. You have a check engine code already anyway. Unplus the maf sensor and start it up again, if the car actually stays on and idles, then your maf is toast. With the maf disconnected, the car will run off the pre-programmed limp-mode maps. Try it.
Old 07-05-07, 01:20 PM
deja
deja's Avatar
update: Pulled the pump, and to my surprise, it was completely dry. The car is still running somewhat rough (at idle). The fuel sending unit IS bad. Is the sending unit part of the assembly, or?
thanks for the advice guys.
Old 07-06-07, 04:56 AM
slickgt1
slickgt1's Avatar
The unit might not even be messed up, just stuck. But since you have it out, might not even be worth it to consider any repair. We that is if the entire thing is not super expensive. Check with the sponsors of this site, they offer good prices and usually will accomodate you fast.
carroll
02-23-24 02:19 PM
COOLIS
11-26-16 04:07 PM
alexk13
06-06-15 07:38 AM
Bourbon
Lexus Vehicles Classifieds
16
01-13-12 08:16 PM
ACS_Ken
03-03-04 10:58 AM
Quick Reply: GS430 stumbling.. help!?
