Bazooka Sub in GS300
I want to replace my factory sub with a bazooka sub that has a built in amp. My question is can i hook up both line level inputs from the bazooka to the one sub output from the factory stereo? If so will it cause any problems?
thanks
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I put in stereo for a while and on step-downs we would connect both. The two pair are for separate left and right channels which would produce stereo sound. If tied together you would be limited to mono but thats what the sub needs anyway.
