anyone know anything about the stock AC system?
Old 06-27-07, 07:43 PM
ballz
ballz's Avatar
Default anyone know anything about the stock AC system?
one speed of my AC fan is the only one that works. there's no low to high anymore. and then yesterday, my AC fan shut down completely for a couple minutes and then started back up to the one speed. I stopped by an AC place today and the guy said it was probably a fan switch but couldnt say for sure. they were busy and nobody was available to take a look at it. anyone have any idea?
if it helps, I got a flip out tv installed right around the same time frame. it was by a reputable shop in town so I'm pretty sure that's not the issue, but I'm not ruling out the possibility.
Old 06-27-07, 07:53 PM
ballz
ballz's Avatar
oh, and the AC blows cold air just fine when its on.
Old 06-27-07, 08:45 PM
GS FONZy
GS FONZy's Avatar
sound like your ac control unit might be bad. try to borrow someones working controls just to make sure that's the problem.
Old 06-27-07, 09:10 PM
ballz
ballz's Avatar
I noticed that the controls will activate the clutch in the compressor, but still no fan.
Old 06-28-07, 02:30 PM
ballz
ballz's Avatar
someone on another board said it might be the blower or blower resistor...? anyone?
Old 06-28-07, 06:43 PM
GS FONZy
GS FONZy's Avatar
your fan is still controlled by the AC/Heater unit. i don't know if you can pull it aparts and try toying with it. if your fan comes on one speed than the fan is working. what is not working is what tells the fan how fast or how slow to go. the swicth for the ac is separate from the fan swicth. i could be wrong about what is wrong, but you have to trouble shoot and that's where i would start.
Old 06-28-07, 10:19 PM
Hectorm
Hectorm's Avatar
Sure is the fan motor. Get replaced. This happen to me before but in other car.
Old 06-29-07, 09:44 AM
ballz
ballz's Avatar
update: I called lexus and they said there was no blower motor "resistor", but instead a blower motor "controller" which was about 230 dollars as opposed to the ~27 dollar "resistor". can anyone verify that this is the correct or incorrect part?
the lexus dealer closest to me isn't that close and I'd like to order the part and install it myself if possible.
Old 06-17-09, 01:01 PM
S-Lex-95
S-Lex-95's Avatar
Default air conditioner fan on one speed only
So what was the resolution to this? My GS400 has same problem. A/C works but fan is only on HIGH no matter if you try to select a lower speed. Fan works the same for heat also. Did you get the "controller" and did that fix the problem?
2ks
RX - 1st Gen (1999-2003)
06-11-21 01:23 AM
65beto
03-24-18 09:37 AM
foreste1
GX - 1st Gen (2003-2009)
03-13-17 09:54 AM
starkid198
07-15-16 02:02 PM
gdoutlex
North Texas Lexus Club
08-24-10 12:01 AM
Quick Reply: anyone know anything about the stock AC system?
