DIY 7 brakelight taillight (cost:$0, time: 15min)
Sorry if this is a repost. I searched but haven't seen anything on CL so I thought I'd post this.
DISCLAIMER
do at your own risk.
Time you need:
took me like 15mins.
Things you need:
14 gauge wire
4 splicers (if youre lazy like me who doesnt want to splice/solder).
![](http://i165.photobucket.com/albums/u73/Coco-bun/Lexus/IMG_0314.jpg)
Cost:
pretty much zero
What you get:
the good
-the top two taillights lighting up when you brake, woohoo.
the bad
-I have heard of one case where the taillight cracked b/c of excessive heat, but IF that happens, I'm buying 01+ taillights. This is probably why Toyota didn't make that top part light up. But it is wired so you can, and even has double filament bulbs...so I why not?
^Cracked 98-00 taillight with this mod
-It also draws more electricity...quite a lot actually.
How:
1. take off taillight.
If you don't know how, try researching. Clublexus logs and google are a great resource.
2. tap into wires...
![](http://i165.photobucket.com/albums/u73/Coco-bun/Lexus/IMG_0311.jpg)
<upper light>..............................<lower light>
black (brake)-----tap----------white/green (brake)
red (small)---------------------orange/green (small)
white/black (ground)------------white/black (ground)
![](http://i165.photobucket.com/albums/u73/Coco-bun/Lexus/IMG_0312.jpg)
3. and you have a working brake light. I'll try to take better night pics tonight.
![](http://i165.photobucket.com/albums/u73/Coco-bun/Lexus/IMG_0313.jpg)
Driver's side is stock, passenger side is tapped with brake light on the top right part of the outter taillight.
Good luck, and again, I am just showing you how to. Do this mod at your own risk.
Props to ClubAristo
DISCLAIMER
Time you need:
Things you need:
14 gauge wire
Cost:
pretty much zero
What you get:
the good
the bad
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/416-1.jpg)
How:
Props to ClubAristo
no problem ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
thought I'd return something back to CL.
1,2,3,4,5,6,7,8...d'oh![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
and forgot to check Banana's site...is it still down?
Is soaristo an active member still?? i need to get in touch with him.
I thought about that but the guy on ClubAristo specifically said its due to the extra filament turning on when breaking.
kit cat
03-23-08 11:22 PM
