Help something wrong with my GS
Car was running fine then I was stopped at a light. Turns green I hit the gas and nothing. check engine light VSC trac lights were on so I thought it had stalled. But it didn't, it has no power unless you floor the pedal and then it feels as if its not shifting gears at all.
Anyone had this problem or know what it might be?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Three for three, TPS. Reseting the ECU may fix it for a little while till the fault trips again.
Limp mode is when the ECU runs with BASIC set parameters for a sensor that has failed. If you get a light on for the air/fuel ratio sensor the fuel trims are locked for that bank based on different inputs, temp, air flow, rpm. Instead of being real time like it is when the sensor is active.
Yes it is. I had the same experience as you and I kind of freaked out because none of my previous cars had "limp" mode. Well I scanned for codes and P1120 and P1121 came up. I also cleared the DTCs but the problem hasn't come back for months.
The two things that need to be replaced when P1120 and P1121 come up are:
-Accelerator Pedal Position Sensor (APPS)
-Throttle Position Sensor (TPS)
Geez Club Lexus is a god send - just had this EXACT thing happen to me.
Couldn't have described it more accuratly. Just knew big bucks were soon to be out of pocket (transmission,engine, etc). whewwwww
Any idea the cost for replacing the;
im going do the ecu reset as a temp fix untill i can get this dun.
This happened at least once a month with my gs4...same exact thing. Thanks to a previous thread on here that I found, I ended up cleaning the Throttle Body extensively, along with the MAF, and my aftermarket air filter....and I also reset the ECU and cleared the codes as well. After doing this, the problem hasnt happened it what seems like over a year.
It was definitely a scary thing to have happen though....it happened on the freeway one time, and I had to slam the gas pedal on the floor to get it to respond
I hope the info above is helpful.
