ants in my ride
If you park your car outside, they might have a nest somewhere in your car. Disturbing, eh?
I had an old Ford truck that had occasional ants in the cabin. After months of seeing an ant or two every day, I finallly saw tons of them crawling around in the passenger wheel well. I went to a car wash and used the pressure washer, and THOUSANDS of ants came out from behind the wheel well liner.
If you park outside, it can happen. I keep my vehicles very clean, but apparently these ants preferred a clean pad.
I had two incidents with these freakin ants so far this spring. In my backyard, while cutting the grass and some bigger ones that actually made it in my house. I put down a couple Combat traps and used that Combat glue which did a good job in luring them to the traps. Within about two weeks , all the ants were gone. Now I don't recommend using the glue around your car but instead you may wanna put it around the openings of the traps at least to bring them to the bait.
