new pics wheels on da whip!
you opted for the stretched rear tire instead of going with a 275/30/20 in the back like most would for the 10 inch wide wheel huh? since this is the case you should dump the car more since you have the clearance to do it. the front offset is also 33...usually the rear is more aggressively offset then the front... did you consult someone from where you purchased these from before you pulled the trigger? you wouldnt have had rubbing issues with a 245/35/20 and an 8.5 inch wide wheel if the offset was correct (38/40)....
i own a tire and wheel shop so i knew what i was gettin in to with the fronts. the tire size will change to the 275 on the rear but i had these tires on the other 20's so i thought i would wear them out before i bought the others. as far as the rub it barely touches the plastic finder well and only on the real hard dips, i plan to take care of that after the 4th of july week!
thanks to everybody for the props keep them lex's rollin!!!!!
