How to turn off ECT light.
I usually drive with the ECT switch on, but then there's that silly green light on the dash. To me, it's getting annoying, and I would like to disable the green light. Can I simply pull the bulb out behind the gauge bezel? How does the bezel come off? I assume you just pull?
olddog - Thanks, you are the man. I actually ended up removing the bezel, and just putting a small square of black electrical tape over the ECT light, so I didn't need to remove the instrument cluster, or the bulb. Since there's a smoke lense on the bezel, you can't see the tape. Took less than 5 minutes.
mr29rose
06-09-07 06:57 AM
ACTIV
01-15-07 12:55 PM
