so i took the part out...now i need a part# *pics*
I have a few different part numbers from my parts list. I will do my best.
22 servo damper 87106-30351 Looks like it is close to the drivers side. 148.92
23 servo mode 1998 to 11-97 87106-30370 066.29
from 11-97 through 1999-2005 87106-30371 151.19 higher of the two on the passenger side.
24 Servo temp 87106-30341 148.92 lower one on the passenger side.
The servo's above are all connected to the evaporator heater core assembly
Book only calls for .5 hours... are you sure you need to move all that to get to it?
There is another servo on the blower assembly
next post see below
I hope this helps. I tried to cut and paste this out but man it got really blurry bad. sorry.
If you can take a picture with your finger pointing to the area maybe I can help more.
B
next post see below
B
the pic below is from the passenger side. you can see the black connector to the right and the empty screw holes from there the servo came from.
![](http://i18.tinypic.com/646etex.jpg)
from the angle you can see the upper servo (which i didnt know was there)
![](http://i17.tinypic.com/6h6xnrd.jpg)
I am going to say its part #24.....the lower servo
B
1999, 2004, 8710630341, 8710630351, 8710630371, airmix, damper, gs300, lexus, mode, model, number, part, rx330, servo
