steering rack??
I have a GS400 with 125,000 miles on and need some advice. As I am driving if I fit a small bump in the road or a change in asphalt the cars will pull either right of left
I have changed the bushings, the tie rods, alignment, balance, but still pretty much the same isssue. Do you think the steering rack might be bad?
I seen a website selling the steering rack for $299.00, but I dont want to just throw money away if thats not the problem. I dont remember it like this when I got the car almost five years ago, but now I cant stand it. The pulling left/right over the smallest bump, I have read about slop in the steering but just seems there should be something that must not be right.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Thanks for your help.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Control arm bushings I did not change. Just changed the steering rack bushings.
I did tighten up the the nut on the rack you mentioned as well. Made things a little better, but theres got to be something else.
Did you change the controll arm bushings? Will that tighten up the front end and the pulling left and right over small bumps?
Also, these bushings will show more of its effects with stiffer suspension and sway bars. tires affect how the front end handles and travels as well. In fact most of the time, it's the tires.
There is a rack on ebay right now. http://cgi.ebay.com/ebaymotors/ws/eB...0200597&rd=1,1
might be worth a try??? B
How are your tires? I had the same problem. I changed everything. My steering rack worked fine too. It all came down to the tires.
now thats somthing I never heard of, hmm??? I never have changed the power steering fluid checked it but never had it flushed. Might give that a shot this weekend.
