BRAKE light problem - GS
Since the winter cold front has moved in, everyday when I leave in my GS, the red BRAKE (parking brake) light comes on in the dash when I press the actual brakes for the car. When I accelerate, it goes away, and then the process repeates itself. I notice throughout the day as the car warms up a bit it doesn't do it as much. Has anyone experienced this? Is it just the cold or is there a problem with my brakes? I have noticed the past week a light sqeeking sound coming from the left front wheel when rolling slow??? Any help would be greatly appreciated. Thanks.
Sounds like your Parking Brake (Rears I think) aren't coming quite detached; like they are being frozen on when you apply the parking brake begore exiting the vehicle. I'd say engage / disengage the parking several times consecutively to give it a good working.
Don't know for sure, but brakes is something I would take to the dealer immediately.
GL and keep us posted.
Hey,
Check this out, I had the same problem on my Tacoma, all you have to do is add some brake fluid and the problem should go away. My brake fluid tank was showing half full so I didn't think it was a problem, but I had just replaced the brakes about 3 months prior (I wasn't gonna re-do the brakes). So I just added some fluid and BAMM! problem fixed.
Hope that works for you.
allen
allen
Originally posted by fasthuh
Hey,
allen
Hey,
allen
Brake fluid is like the other critical fluids where they don't follow the theory of 'a little is good, so a little more must be better' - they have a range they are to be maintained within.
Also notice that it may be temperature or weather realted....
Just my .02
Dexter,
Point well taken, but from reading his post, I had exactly the same symptoms (Brake lights coming on and off from acceleration). I also thought that the emergency brake line need adjustment, but that checked out fine for me. I was just giving him my personal suggestion.
About the slight squeeky noise, possibly the brake sensor, I think that part would require brake replacement, but I can't say cause I can not see the pads, you can try cleaning it off with a brake cleaner.
good luck
allen
good luck
allen
Couple of long shots...
Maybe related, but we should all USE the park brake from time to time, but I expect most of us never do. I engage mine once in a while because I understand it helps calibrate it and make sure it doesn't get stuck. So 400 - you might try just engaging and unengaging the park brake a few times.
Also, I've noticed that even the slightest 'knock' of the park brake pedal on my car will make the park brake light come on when I start the car. I've often had to pull the brake release even though there's no resistance when I do so indicating the brake wasn't really engaged at all. Perhaps doing the above might help this too...
That red brake light is indicating your brake fluid is running low. A reason for why it's low is because your brake pads are wearing thin (which would explain the squeaking sound you hear).
I had the same thing happen with my SC (but brakes weren't squeaking) and I put in a little brake fuid and the light went away. It looks like your due for new brake pads.
mackel53
12-14-08 12:48 PM
