Whats needed to install an aftermarket head unit?
Hello im new to this site and just recently switched from a Cadillac STS to a Lexus GS300...and now I wonder why I didnt buy the Lexus a long time ago. Anyways I have had my GS for about a month now and I love everything about it. The 6-disc is a nice feature but only half of the Stock player lights up..which seems to be a problem with a few of them after researching. My question is what is needed to install an aftermarket Double Din DVD/Nav unit. I remember on my Cadillac the new harness plugged into the amp in the trunk, and all the wires had to be extended to the new head unit, is this the same for the GS300? Also does anyone have any good recommendations for what Brand of unit to go with? I want it to be able to play DVDs while driving so it must have a bypass code or have the ability to be set up to do so. Thank you for your help.
yes the wires have to be extended to the amp behind the glove box..............also the harness you need will not be plug and play you will need to relocate some of the wires in the harness............ you will get all sorts of info from members on here about their recommendations for head unit. i've recently installed pioneer avic d3, i like it cause its priced right commpared to others and it recently came on the market. i suggest you do alittle research on here and your local audio shops on which unit will suit you best!
The Eclipse units are some of the cleaner double dins out there and they can be permanently bypassed by grounding out the parking brake wire.
www.eclipse-web.com
www.eclipse-web.com
Make sure you get your double DIN face plate and brackets OEM from Carson Toyota. I just got mine in today, PERFECT match to the AC unit and ash tray. Don't mess around with any other after market Double DIN kit.
Avic D3
Thank you. I bought a Pioneer Avic D3 today and the L-tuned double din dash kit is on its way. I have read plenty of threads on how to make it play dvds while driving, that will not be a problem. The question I have now is will I be able to find a plug that needs no modification? And do I just have to extend the wires from the HU to the new plug that goes into the amp and keep all factory speakers/sub? I was kind of iffy buying the new HU because of all the problems I have read on installing, but I hope you guys can lead me in the right direction. I figured i've seen pictures of it installed on here so it can be done, I just need to know what I need and what mods need to be made. Thank you.
https://www.clublexus.com/forums/sho...l+radio+in+2gs
look at pics of my install it might help some...........as for the sub it's not going to work after the install............but you can remove the factory amp and replace it with a small amp to power the sub and use the wiring from the old amp to hook up the new one!
Dusouth- Any more info you can give on an install??
I have a Z1 coming in and a JL Amp and Sub to accompany it. I'm going to keep the factory speakers for now, but lose the sub. Should I just pick up a 4 channel JL and run the car speakers through that (obviously I figure that i'm going to lose the factory amp.)???
Any other info or links would be greatly appreciated.
my headunit is more than enough to power the factory spkrs...............i think you should just amp the sub, if it isn't good enough for you than maybe amp the cabin spkrs, but they don't hold alot of power and you will probally blow them after a while!
use your EQ to remove any low freq on stock mids and they should sound pretty good.
