How To - Change The Tension On The Trunk Lid - One BIG Pic
#31
The diagrams are only on the "w/o spoiler" category, but buy the "w/spoiler bars" if appropriate. You're going to need both left and right.
No tools are necessary if you've already gotten to see the holes, it's obvious how to replace them if you just look at your existing bars.
Just note that you'll have to use some muscle to load the torsion onto the bars to install, they don't just slip in.
Well maybe they slip in if you fork over money for some completely unneeded custom SST overdesigned for this job.
#32
http://www.parts.com/oemcatalog/inde...layCatalogid=0
#33
Even if they're too springy initially, they'll die down after a little while, or you can swap in one of your existing bars if it's really too strong out of the box.
#36
anyways the new ones should be here this week and i will give it a try. i ordered the ones for the spoiler model to try and give it some extra OOMPPHHH...
#37
well ordered these on the 18th from parts.com....got a message 3 days later saying they wouldnt ship them to a different address since its not my billing address. WTH why give me the option then?
The order just goes to the dealer has the lowest price, but then the parts dept. for that dealer fulfills the order based on their own policies.
I've had a recent order where if I were to buy honda and toyota ATF together, the honda parts would get cancelled with a "we don't ship fluid" whereas the toyota dealer shipped ATF fine. Meanwhile, I pay the full shipping/handling fee even though it's only a partially completed order.
But once you know the lowest price dealers, you can just order from them directly.
For Lexus, last few times, it's been Pembroke Pines Lexus out of Florida:
http://www.trademotion.com/partlocat...?siteid=214082
for example.
#38
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
thanks for the heads up ray this def is true
#39
you know i was very skeptical about these actually working but i was also curious so i bought a set and tried them. well thanks ray the new ones DEF work and for $55.73 SHIPPED i am happy with it. the ONLY problem i have now is the custom holes i drilled awhile ago give it to much tension EVEN with all my dynamat they slam up to the max,bounces back and then slams forward some till it settles back fully open so now it has to much force
the 3rd OEM hole with my dynamat opens about 1/2-3/4 of the way open so im gonna end up drilling a hole in between my OEM 3rd hole and my custom one and it should work out fine.
thanks for the heads up ray this def is true![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
#43
My 1980 Turbo Trans AM still has factory bars and with the factory rear spoiler, it still pops up when you turn the key. Lexus just used excessively weak bars, thats all.
#44
so i had the same problem with my trunk since i had the spoiler and the truck would easy fall and close, this once it actually fell while i was getting something and left me a nasty bruised back.
i used to this DIY without any luck so i decided to drill my own hole, like so
i would recommend doing this if the factory strongest setting is still not fixing the problem but be very careful not to over drill as it may accidentally drill through places you dont want to drill
#45
Did this as soon as I read this DIY, great write up..
I opened my boot, and as i sat in the car with a screw driver to pry the clips out the lid closed and the hinge hit me in the side of the knee.. have an epic bruise now -.- but now the trunk opens by itself
worth it? I think so.
