need quick help for fluids
i need to find this quick but the search option has failed me
i need to do a drain and fill on my 99 gs400. i need to know what type and how many litres/quarts/imperial quarts i need for the following:
-transmission? i was told toyota type T-IV 1.9litres/1.42quarts/1.7imperial quarts, but the mechanic says it needs more.
- differential? SAE 90 API GL-5? i am running a supra TT LSD rear end.
- coolant? i am clueless on this one...
thanks
thanks
I think the tranny requires 2 quarts maybe a little more. I recently used Amsoil ATF as suggested by DaShocker and many others. It definitely makes the tranny shift very smooth and is Lexus type T-IV compatible.
As far as the LSD, I also have a supra 3.76 LSD. I used Royal Purple Max Gear 75W90; you need about 2 quarts maybe a little less. You fill it until it starts to pour out. That stuff works great for this type of LSD.
The coolant, I have no idea; just use what's recommended.
GL!
GL!
i'm going to have trouble with the coolant. the previous owner did not use toyota red and it's conventional green coolant. i'm thinking if i did just a regular drain and fill, it's not going to be enough... not sure what color green and red mixed together will give me
Oil - Engine, with filter..........5.7 quarts
Coolant - Cooling System, Initial Fill..........8.0 quarts
ATF - Automatic Transmission, Initial Fill..........2.0 quarts
ATF - Automatic Transmission, Total Fill..........8.8 quarts
Differential - Differential, Rear..........2.8 pints
heh... thanks
for the amsoil atf... is this the correct one?:
http://www.canadiantire.ca/browse/pr...4bcc1a911d7a58
i went to read up on dashocker's thread about amsoil atf... any idea how many quarts i would need to if i do the power fluid exchange? there is a shop that has that unit, but they do not carry amsoil, so i would have to bring it in myself.
Well, probably the amount that GSoup mentioned above for a complete fill. Maybe more because you are going to want to flush it first with new fluid then drain then do a final re-fill again. Mine was expensive because Amsoil is not cheap especially when you have to buy 8 or more qts. I think I paid almost $100 just for the Amsoil ATF when they were doing my tranny flush and installing my PI TC; if my memory serves me well...but it's been a little skittish lately. lol
Rock-a-Lex
Performance
11-24-08 07:01 AM
