Does anyone have 20x9.5 rear wheels with a 40 offset?
Im trying to figure out exactly what size wheels and tires to but for my 2002 GS430 for the rear. Does anyone here have 20x9.5 rear wheels with a 40 offset? Will this size wheel require any rolling of the fenders? I do not want to have to do any modifications to my fenders. I was planning on this wheel with a 265-30-20 or a 275-30-20. Will these tires fit on this size rim without having any clearance or rubbing issues? Once again, I am not willing to modify my fenders to do this. All help and pictures is greatly appreciated. Thank you in advance.
Jason
Jason
Jason
Jason
A 40 offset ought to give me a good size dish right? Im going w/ staggered rims. 20x8.5 in front with a 35 offset. So is there an even better rear wheel combo I could do w/o having to modify my wheel wells?
If I were to want to stick with only a 9.5" wide wheel...what offset would be perfect for deepest dish look possible w/o having to worry about rubbing/clearance issues?
i know you already sent me a pm but here are pics of mine.
Hypersilver/Staggered EXE Konvex
20x9 +37 Front & 20x10 +35 Rear
Dunlop Sport Maxx Tires
245/30/20 F & 285/35/20 R
KYB Shocks/Eibach Pro Kit Springs
NA/T Supra Brake Calipers Front
SP Cross Drilled/Slotted Rotors Front
![](http://i49.photobucket.com/albums/f279/CarbonGS/My%20GS/5-3-07installednewsuspension.jpg)
I did have to mod my fender by shaving it. the +35 does stick out a little bit. But i am also running a pretty fat tire set up for that wheel
Ok, Im having difficulty understanding this. Tirereack reccomends a 20x10 with a 45 mm offset. Will this have a smaller lip and stick out farther than a 20x10 with a 40 mm offset, or will it be further in with a smaller lip? Sorry guys, this whole staggered thing is driving me nuts. My Lincoln LS has 20x8.5 all around and has the same offset.
anyway, cyclemax, inside doesn't really matter much at this point, you can go a lot more inboard and still not hit anything
imho, if you have to stick with 9.5, i had +38 and had no problem with 275 tires at all. not anything lower than that, you might start to get pretty close to the fender lip
Well, I have decided to do a 20x10 wheel...but Im still undecided on the offset. Either 40 or 42mm. Im going to use 275/30/20 tires. Will I have clearance issues if I choose to do this set up with the 40mm offset instead of a 42? Thanks for everyone's help so far. This is my last question inregards to this I swear!
