Quick Offset Question. Need help FAST!
OK CL members, I need a quick question answered. Will this rim setup work?
Front: 19x8.5 +13mm Offset
Rear: 19x10.5 +25mm Offset
If it does, can anyone recommend the proper tire sizes? I'm thinking 245/35/19 in the front and 275/30/19 for the rear. Questions and comments are appreciated.
I was only using these tire sizes because I might be able to get some in these sizes for less than retail..
i c that you don't plan to really lower the car. your offsets should be nice, but you'd want a stretch on the tire if you don't want to rub or better yet have someone roll your fender too so when you have passengers or you go on a dip your free from rubbing issues.
Has anybody mentioned that there will be fender modification involved with these wheels specs?
245/35/XX are both tires specs for 19s and 20s (for the 2GS), thats the reason why 20s are an inch over the OEM tire diameter specs.
https://www.clublexus.com/forums/sho...d.php?t=299679
This guy is running +18 in the front and +25 in the rear.
Since you don't plan on lowering the car, i'm thinking you don't want to mod the fenders either correct??
If that's the case, I would pass on those wheel specs.
My .02 cents
So are you saying that the rims that I want to put on the car with the offsets of 19x8.5 +13 and 19x10.5 +25 are too aggressive of an offset for them to fit on the car? For these offsets, what tire sizes would be recommended? How much fender mod for slight lowering? (About an inch?)
jbbnet
Wheels, Tires & Brakes Forum
02-07-03 12:29 AM
