00' GS400 starter $1200 @ dealer
Third time, never fails... owned a 93 GS 300, a 98 GS 300, now a 00 GS 400. ALL THREE eventually had the infamous starter/solenoid clicking problem. Replaced solenoid/starter the first two GS 3s at dealer for $360 or so several years back. Now my GS 400 is having the same problem, but dealer is quoting me $1200! 7 hours of labor at $110 due to the starter being WAY the hell under the V8.
I HAVE to get it replaced, I know how it goes.. It had happened to me twice already... I don't want to wait till it just dies and won't start at all. $1200 on the V8, OUCH>
Dealer is Pohanka Lexus in Virginia, Washington DC area.
I haven't forked over the money yet.. sleeping over it. The problem is I CANNOT get any recommendation here in the northern virginia area of a good Lexus independent shop!!? Since it will be rather labor intensive to take the V8 out to reach the starter, I don't want to take it to Jiffy Lube or some ghetto gas station repair shop either. Hoping someone here would recommend me a shop here in N. Va.
That price is from a shop that specializes in imports. it's not lexus specific, but I've seen the shop do many lexus and toyotas so they were okay in my book. For the cheap labor, I just had to let them to do it. It was raining that day and my car was dead on the side of the road. ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
a lexus-independent shop wanted $750 for parts and labor, $150 more than what the shop charged me.
it's the mechanic behind the work that counts. Fortunately, the guy who did my car gets very good feedbacks.
And yea, $50/hr is cheap, which is why I couldn't resist letting him do my engine mount install too. $200 for labor (4 hr)
I have replaced the starter on my 98 LS400 a year or two ago. Here is the link to a lot of good info, parts need, and pics:
https://www.clublexus.com/forums/sho...arter+went+out
There are pics, and the items you would need to perform the task yourself. Why don't you take a crack at it? It would be much easier for me now to do it, then the first time around. I ended up spending about $200 if I remember correctly, for everything. I could have saved some more money if I didn't buy all these gaskets. I had to work with zero help as I couldn't find any info on starter replacement on the newer 1UZ-FE's.
If your pretty good with a wrench and have sometime on your hand, I would suggest you do it yourself. I'm in the Vienna by the way.
Some pics of the work involved... thought someone might be interested in this...
KEEP IN MIND, THIS WAS DONE ON A '98 LS400
![](http://us.lexusownersclub.com/forums/index.php?act=attach&type=post&id=5085)
![](http://us.lexusownersclub.com/forums/index.php?act=attach&type=post&id=5095)
![](http://us.lexusownersclub.com/forums/index.php?act=attach&type=post&id=5102)
Important Part Numbers:
pic of gasket needed:
![](http://us.lexusownersclub.com/forums/index.php?act=attach&type=post&id=5124)
Pic of the engine bay upon completion:
Also, other parts I needed for the project are the following (this is going to save you sooooo much time! wish I knew beforehand)
16341-50020-GASKET, WATER OUTLET (2 needed)
17171-50020-GASKET, INTAKE MANIFOLD (2 needed)
17176-50021-GASKET, AIR SURGE TANK (4 needed, ONLY needed if you want to separate the upper and lower intake, which I STRONGLY advise against, the more parts you separate, the higher prospects for problems later down the road).
281005006284 - REMAN STARTER (incase someone needs this.)
I too recommend SRT in Beltsville, MD. I'm sure they'll def beat the dealer's price by far. They've worked on quite a bit of gs300/400 and even TT'd a few. Give them a call: 301-982-4600 ask for Kellen/Mo.
www.swiftracing.com
www.swiftracing.com
I will second this. I did mine and it really was not bad. I was a little scared from all the talk on this site, but it was easy compared to the way people make it sound. You do need to be somewhat mechanically inclined.
