ECU Pinout Values
Old 02-28-11, 12:18 PM
JeffTsai
JeffTsai's Avatar
Search for my other thread on pinouts here on cl. I have an updated one with working links and additional pins.
Old 02-23-13, 11:33 PM
Waasil
Waasil's Avatar
Thank you ......
Old 02-23-13, 11:44 PM
JeffTsai
JeffTsai's Avatar
I updated the post and fixed the broken links. Check #1 post for the GS300 pinouts.
Old 02-05-15, 09:44 AM
g099521
g099521's Avatar
Do you happen to have the transmission signals or full pin list for the ECU in 02-05 GS300s?
Thanks!
Old 03-11-16, 11:03 PM
maafala37
maafala37's Avatar
Default Help!!
I need help, I bought a 2002 gs300 engine wire harness for my 2001 gs300 thinking it's a year apart I could use it. Some the wires won't plug into the ecu? What can I do?
Old 11-26-16, 10:08 AM
juju69
juju69's Avatar
Default s10 2jzge
Originally Posted by JeffTsai
Also, keep in mind. They way Toyota drew up the diagrams...the images below show the plug wires backwards from how they plug into the ECU. Like, if you were to unplug it and look at the plug head on. Just match/count the knotches in the connectors when you're wiring up to make sure you don't have it backwards.
Preview of what it looks like
​​​​​​​will try to day get my truck goin
Old 05-19-18, 12:45 PM
OmariMack
OmariMack's Avatar
Due to popular demand...I'm making some ECU pinout charts.
This should be helpful for those of you installing SAFC's and it even includes all the pinouts needed if you're planning to put in a standalone ECU. I double checked all the values and they SHOULD be correct. Just don't blame me if the ECU lets out some smoke lol.
Just be patitent and I'll release more as I have time. These take about 1-2hr each to make lol. So far I've completed the GS300 98-00 and 01-05. I'll do the GS400/430 eventually lol.
02-05 GS300
Full size in link below
http://powerdynamix.com/DIY/Engine/E.../GS3_02-05.jpg
98-01 GS300
http://powerdynamix.com/DIY/Engine/E.../GS3_98-01.jpg
Do you have ECM pinout for 1995 to1997 Lexus Ls400..
Old 05-23-18, 10:31 PM
Alexdd01
Alexdd01's Avatar
02-05 GS300
98-01 GS300
Hi JeffTsai. I'm new here.
Just wanted to ask. Are all the pinouts in your 99 gs300 diagram for a stand alone system.
I'm in the middle of a 2jzge vvti conversion from a gs300 to a 1973 toyota crown ms65
Old 05-24-18, 08:50 AM
captainva
captainva's Avatar
The pin outs are for any system. This just shows what each wire going into the factory ECU does/connects to which you need to know if you are rewiring for a standalone. Also he is almost certainly not going to respond. He hasn't been on the forum in a long time
maxEX84
09-01-15 05:48 AM
Naryu
Performance
09-11-13 10:12 AM
Blk97SC300
09-27-10 06:19 AM
BLACKPIG99
03-06-05 05:57 AM
Shinchan
08-28-01 09:40 AM
Quick Reply: ECU Pinout Values
