Help with gs300 engine wire harness
Does anybody know if the 99 gs300 engine wire harness will work for an auto 02 is300 engine? Will it plug right into the ECM and work? Any help is appreciated.
No the 2 harnesses have different pinouts. What you should be able to do is use your current harness on the IS motor. Basically strip the whole original harness off the IS motor and replace it with yours...then it should all plug into your stock GS3 ECU. All the connectors should be the same shape and also in the same place.
LexuSupra1
03-08-10 07:13 PM
